Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 06-25-2006
TelePaul's Avatar
TelePaul TelePaul is offline
J to the R O C
TelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond repute
Distortion plug-in
Hey guys, loving cubase SE 3 but im wondering about the 'distortion' and 'da tube' inserts...umm..is it me..or are they just bad?
Originally Posted by Gummblefish
Went out yesterday all day long and spent 125 quid on a bender (not literally a bender )
Old 06-25-2006
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
The only thing I've used "da tube" for is dirtying up vocals and keyboard parts. Most distortion plugs are pretty limited, imo. What exactly are you trying to do? For adding distortion to guitars, I'd look at the simulanalog plugs. They're free and they JCM900 plug sounds pretty good. MDA also makes a plug called the mdaCombo that has a few speaker simulators, which can be useful to put after a distortion plug, to make it sound a bit more "amp-like."
"That was so terrible, I think you gave me cancer!"
My tunage
Old 06-25-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Most distortion and 'da-tube' type plugins are not for guitar. They are for putting some hair on an otherwise clean signal.
You are looking for a guitar amp simulator.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 06-25-2006
TelePaul's Avatar
J to the R O C
oh cool, yeah i have some guitar combos which work well, ill try the distortion plugs for other things.
Old 06-26-2006
noisewreck's Avatar
noisewreck noisewreck is offline
Sound Destroyer
noisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond repute
Also, you can get a lot of milage out of Quadrafuzz.
The other thing is, don't use single-band distortion plugs all by themselves. There is nothing that says you should just put DaTube or Antares Tube on a track, and crank it up to "11" and hope for the best. I routinely sandwitch those between EQs, filters, flangers, phasers, etc. sometimes even using more than one instance. Try using 2-3 of them with mild settings, sandwitched between EQs and other, rather than one instance cranked all the way up. This way you gain an enormous amount of control and soundshaping possibilities.
Think of how stupid the average person is, and realize half of them are stupider than that.
--George Carlin
Old 06-26-2006
TelePaul's Avatar
J to the R O C
whoah thanks for that man. I was thinking of sketching out sum drums with the lm 7, mixing them down as an audio file then bouncing it back in and applying some drive...to improve on the fake sound. Yay or nay?
Old 06-26-2006
noisewreck's Avatar
Sound Destroyer
double post
--George Carlin
Old 06-26-2006
noisewreck's Avatar
Sound Destroyer
Well, it depends on what plugs you're gonna use. Try Magneto for example, but don't push it too hard
Another thing you could try is make a copy of the track and apply the distortion/drive to the copy, then mix it in to taste.
When applying distortion to drums, I find that snare and sometimes kick benefit the most, with things such as cymbals and hihats getting too harsh and brittle. So, if you can, I'd suggest you bounce the snare and the kick separately, so you can have finer control.
Another thing you may consider is putting an EQ or a low-pass filter (2 pole, i.e. 12dB octave LPF usually works best) before the distortion plugin and rolling off the hights before the distortion. Just play with the cutoff frequency, until the irritating edge is gone. You may also need to follow the distortion with another EQ to control any mid-range honk.
Finally, experiment!
--George Carlin
So I tried out the new Antares Avox plug. . . BJW The Rack 1 03-16-2008 08:36
Splitting audio signals for layers and channels walters Recording Techniques 19 11-20-2005 03:40
Amp Distortion vs. Pedal Zona Mona Guitars and Basses 35 08-18-2004 14:25
We All Love Distortion timmerman Guitars and Basses 28 08-02-2004 11:25
distortion sound problems Jtrain42 Recording Techniques 3 09-03-2003 11:00
