Recording to seperate tracks
I apologize if you have seen the following question 100 times already. I am interested in recording very simple songs to my computer. I am using an Edirol UA-100G and Magix Music Maker 10 Deluxe. I have made drum tracks using the Magix software, and I want to record the songs piece by piece with a keyboard. I have everything hooked up and I can get it to record, but there is a slight problem. When I use the UA-100 to monitor the drum track and record over it, I end up with two tracks: the original drum track remains, but the new keyboard track also has the drum track incorporated. I would like each track to be seperate so I can individually manipulate them with effects and volume. Is this just a quirk with the software? Is there a way to monitor playback independently from the UA-100? Any and all help is greatly appreciated. Thanks!
I dont know much about this program. But if you can make a new track and asign it to an input on your card, your set.
Iron What?
I can not use different inputs because I am using the same keyboard for each track and then dubbing them over each other. I am recording each part individually. I want to be able to monitor the tracks I have already recorded then record a new track over them. However, each new track includeds all the previous tracks I have recorded.
| the Basics | fuquam | Mixing / Mastering | 26 | 02-26-2007 18:45 |
| any secrets 4 using vs 1680ex... | drew1 | Roland, Boss, VS Series Forum | 7 | 07-29-2003 22:54 |
| Recording stereo or mono tracks -What's best? | CTyankee | Newbies | 6 | 06-10-2003 14:36 |
| Recording a big band with 8 tracks | Englebert | Recording Techniques | 3 | 10-31-2002 06:37 |
| Problems getting Aark Playback of laid tracks thru Headphones while recording audio | bloozguy | Cakewalk / Sonar Forum | 10 | 10-26-2001 15:21 |
