Old 06-24-2006
rockabilly1955's Avatar
rockabilly1955 rockabilly1955 is offline
Dedicated Member
rockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond repute
need help with mixer to mr8
i have a yamaha mg8/2fx mixer and when i connected it to my fostex mr8, the sound was almost gone. Like it lost everything in the mixer to mr8 transfer process? i ran the yamaha "rec out" output to the mr8's 2 line inputs. Since the yamaha "rec out" uses an RCA typle connection and the mr8 line inputs are 1/4, i had to use adapters. Can anybody tell me how to run the mixer to the mr8 without losing any sound? i must've did something wrong. thanks
Old 06-24-2006
ch2os7's Avatar
ch2os7 ch2os7 is offline
Dedicated Member
ch2os7 has a reputation beyond reputech2os7 has a reputation beyond reputech2os7 has a reputation beyond reputech2os7 has a reputation beyond reputech2os7 has a reputation beyond reputech2os7 has a reputation beyond reputech2os7 has a reputation beyond reputech2os7 has a reputation beyond reputech2os7 has a reputation beyond reputech2os7 has a reputation beyond reputech2os7 has a reputation beyond repute
try this
I have a UB802 and run from the mains to the MR8. I think record out is line level.
Your Yamaha should have main outs. Run them to the inputs on the MR8.
If the Yamaha is a powered mixer DO NOT USE THE SPEAKER OUTPUTS!
Lighten up!
Old 06-28-2006
Paj Paj is offline
Force of Nature
Paj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond repute
The Line Outs/Ins on the MG (and UB, MX, VLZ, etc., etc., ) are usually at +4dB ("pro") levels, and RCA Tape/Rec Outs/Ins* are usually at -10dB ("consumer") levels. The main outs, aux sends, and insert sends should all work fine with the MR8 1/4-inch inputs.
Paj
8^)
*these are the connections that you usually want to use for cassette decks, home CD recorders, receivers, inexpensive sound cards, etc.---usually other units equipped with these jacks. The signal from these jacks is about 1/30 as "strong" as a Line Level (+4dB) signal.
Paj
8^)
8^)
Mixer hookup question Giganova Mixing / Mastering 7 06-29-2006 09:54
A little dissapointed with FOSTEX MR8 sound quality vs PC recording crgl Fostex Forum 9 11-11-2004 13:16
Delta 44 vs. Windows Recording Mixer. God help me. Shepherd Digital Recording & Computers 2 06-09-2003 07:39
Help! How to route my mixer so I can monitor effects using my computer kelitupu Newbies 3 05-10-2002 01:38
my recording setup - NEEDS HELP sykotic Digital Recording & Computers 12 10-06-2001 17:26
