Go Back   Home Recording > User Forums by Brand > Cool Edit Pro / Adobe Audition Forum
Reply    Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 06-22-2006
Shugidy Shugidy is offline
Newbie
Shugidy is on a distinguished road
Sampling rate & resolution
jus a quick question ... what is this ?? is it the higher the sample rate the better quality ?? and the resolution too ... what is the difference when recording with a higher resolution then a lower one ?
Old 06-22-2006
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
The sample rate determines the highest frequency that can be reproduced (Google "Nyquist Theorum" for more). Human hearing is limited to around 20Hz to 20,000Hz. A 44.1kHz sampling rate (like a CD) will accurately reproduce 22,050Hz - Slightly higher than the basica human hearing range, and considerably higher than a lot of audio equipment.
Got that so far?
Bit depth (a.k.a. word length) is measured in bits and is a measurment of the resolution OF the sample. A 1 bit sample has only two possible values - "ON" and "OFF." When you go up, the numbers go up exponentially - On a 16 bit recording (like a CD), any one sample (there are 44,100 of them per second) can have one of around 65,000 values. That's a reasonable resolution. A 24-bit signal on the other hand will have one of 16.7 million values - A huge jump in accuracy, and basically the "standard" word length for audio recording.
So what you find the majority of the time - Rookies, Hobbyists, Semi-professionals, Recording Top Guns - is 24-bit recording *at the target sample rate* (44.1kHz for music CD production, 48kHz for video, etc.). Some prefer to record at higher sample rates, others don't. There are sensible arguments on both sides. But one thing that few (if anyone) will deny is that if you can't get 44.1kHz to sound absolutely wonderful, going up to a higher sample rate isn't really going to help.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 06-22-2006
superspit's Avatar
superspit superspit is offline
idiots unite!
Location: I hit a live electric bass repeatedly with a maraca, so I needed to mic the maraca and the bass amp at the same time.
superspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond repute
Smile
Sampling rate and resolution must be taken into account when recording digitally. For example, in a CD, digital sound is encoded as 44.1 kHz, 16 bit audio. This means that the original wave is 'sliced' 44,100 times a second - and an average amplitude level is applied to each sample. The variety of different amplitude values available is dependent on the resolution. 16 bit means that a total of 65,536 different values can be assigned, or quantized to each sample. Therefore, the higher the sample rate and resolution, the higher the quality of the audio, because a wave closer to that of the original audio can be stored. For comparison, DAT can store audio at up to 48 kHz, whilst DVD-Audio can be 96 or 192 kHz and up to 24 bits resolution. This affords a significant increase in sound quality.
Hope that helps?
Ofcourse, there will be those who disagree with the above, as they believe that the extra space required, on a hard drive, for example, is not proportional to the potential increase in quality of the sound being recorded. And that's fine too!!
Superspit
G.F.C.G. membership #:000038.
"I love sitting at a big console with blinking lights and knobs and feel like Mr.Sulu on the bridge of the Enterprise"
my shit!
http://www.soundclick.com/bands/page...?bandID=742373
www.myspace.com/obzcure
Old 06-22-2006
dobro dobro is offline
Moderator
dobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond repute
John, if CD players played 88.2, we'd all be recording and mixing and burning out stuff at that rate, right? And happier about it in terms of sound, right?
Old 06-23-2006
Eh, most gear out there can't handle those frequencies anyway. Microphones, preamps, compressors, amplifiers, speakers -
24-bit resolution is important to me - I wish CD's were 24-bit.
88.2kHz is important to dog whistles - If anything else in the chain could reproduce the signal in the first place.
Gee, that sounds negative - I don't mean it to. I actually have several pieces of gear that can handle those frequencies - But I still don't bother recording at high sample rates. I'll admit that some of the upsampling plugs I've used probably wouldn't have as much "magic" in them if they didn't upsample. But as far as actually capturing the sound, 44.1kHz, done well, sounds excellent.
Old 06-25-2006
Moderator
Okay, fair enough. But why would you like CDs to be 24-bit?
Old 06-26-2006
16-bit = 65,000 possible values (resolution detail)
24-bit = 16.7 million values.
That's pretty serious resolution...
Old 06-27-2006
Moderator
So - bitdepth is a more important determinant of audible resolution than sample rate...
Interesting. I would have thought it was the other way around. That's one of the many reasons why I'm not an engineer.
What sampling rate to record in? Myriad_Rocker Recording Techniques 3 10-24-2005 18:25
Can't set higher sampling rate: Cubase SL Westridge Cubase User Forum 0 05-15-2005 00:27
sampling and depth rate radiorickm Newbies 7 06-09-2004 10:33
I apologize for this post: Sampling Rate Ptron Digital Recording & Computers 7 09-28-2003 06:26
Sampling rate - which one to use? A Drummer Digital Recording & Computers 1 04-14-2003 16:39
