Old 06-21-2006
nillapoet nillapoet is offline
Newbie
nillapoet is on a distinguished road
low monitor sound
when i play back music through my monitors it's really quiet and i'm not sure why. all the levels on my comp and on the monitors are turned up... here's how i'm set up...
i have active behringer truth monitors hooked up to my m-audio mobile pre/audiointerface by xlr cables which is plugged into my comp.
any possible ideas?
Old 06-29-2006
.:Wyze Loc:. .:Wyze Loc:. is offline
Senior Member
.:Wyze Loc:. is infamous around these parts
the monitors prolly need to be powered
what kind of monitors are they?
Old 06-30-2006
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
In general it's not good policy to plug your monitors directly into your interface.
I recommend a small mixer like this one to buffer and to boost your signal to the monitors.
...now in HD.
Old 06-30-2006
warble's Avatar
warble warble is offline
Registered User
warble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond repute
"i have active behringer truth monitors".
Active typically meaning monitors powered by built-in amps.
Old 06-30-2006
daav's Avatar
daav daav is offline
Flailing up a storm.
daav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond repute
THere are a number of things that you can consider as well, but making sure your monitors are powered is of course the first (either self powered (actives) or through an amp (passive). if you ahve passive monitors you definately need to put sopmehting between the interface and the monitors, but not the little mixer linked above 9it is not powered with an internal amp)
Most interfaces have software drivers with a control console. On mine (echo;s version) there are playback output controllers and a mainout controller (either or both can affect eh sound level being put out) alsoi there is the selector between the pro audio connection or commericail output level ( +4 or -10 db or something similiar) and depending on how that is set there can be a big differene in the level. Check that stuff.
You recording software of course also has a built in mixer with various sound level controls, include the main output.
Daav
Old 06-30-2006
warble's Avatar
Registered User
I'd put something between the interface and the monitors too. I don't have active monitors, but I'm using a Presonus HP4 which has a handy-dandy monitor level knob. I run my Layla 3G into the inputs, and the outputs run into my Hafler amp. The HP4 is balanced, but only 1/4" - no XLR.
You get the idea (maybe).
A small mixer would work just as well for the same purpose!
Old 06-30-2006
Reggie's Avatar
Reggie Reggie is offline
PutsTheLotionOnItsSkin
Reggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond repute
Well....first he needs to get his levels under control. Taking this low-level signal--which could be due to a software volume slider hiden somewhere accidentally being lowered, and possibly giving him a low-resolution/low-volume signal--and boosting the crap out of it may give him less than optimum sound. I would look into the interface's control panel in the computer. And if Windoze is using the interface as its main playback card, you may have another secret hidden volume slider thing to deal with in the Windows control panel.
Old 06-30-2006
Reggie's Avatar
Low end from speakers vibrating 1x12 combo? alanfc2 Guitars and Basses 3 10-27-2006 19:01
Effect of low volume on monitors beezelbubba Mixing / Mastering 3 02-17-2005 10:05
Audiophile 2496, Low level output. Palomares Digital Recording & Computers 4 07-24-2004 09:37
Help needed?Input Levels too low ivan1 Newbies 5 01-30-2003 14:54
