Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 06-21-2006
studiodee studiodee is offline
Newbie
studiodee is on a distinguished road
Tascam DM3200
Hi Studiodee calling
I have a Tascam DM3200 digital mixng board along with the Motu MK3 2408, I want to work them both together. New at this digital domain world. I need to know which is better, 1. to put all keyboard and modules, outboard gear, etc in the 2408,and then go out of the 2408 into the mixing board. Or #2 put everthing into the mixing board and then go out of the mxer to the 2408. I am also using Sonar 5 pro. I also know the key is the routing on theDM3200 Can someone out there please help me with some sugesstions. I am also having problem with exactly where to put my monitors in the DM versus the 2408. Very confused about this. Everything is working it's just what is a better connection. and how to do this routing.
Despearate and confused Studiodee
Old 07-05-2006
In Tune Audio In Tune Audio is offline
Dedicated Member
In Tune Audio is on a distinguished road
I have the DM24
What I would suggest is to plug everything into the DM3200. Then you can use it for monitoring and save your CPU or any latency issues that can arise from monitoring through Sonar.
Old 12-07-2007
qrs qrs is offline
Newbie
qrs is infamous around these partsqrs is infamous around these partsqrs is infamous around these partsqrs is infamous around these partsqrs is infamous around these partsqrs is infamous around these partsqrs is infamous around these partsqrs is infamous around these partsqrs is infamous around these partsqrs is infamous around these partsqrs is infamous around these parts
I own a dm3200 and also the 2408mk3 and I hook up everything into the mixer. That way you can route whatever signal (mic, keyboard, guitars) into whatever output you want. And, I use DP4.5 and it lets me route signals there as well. Oh man, I love the routing system on the dm3200. Have your monitors hooked up from the dm3200 as well. The dm3200 is your main area of work....not the 2408. Control everything from the dm3200.
Old 12-08-2007
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
If the two are connected via tdif then I would just connect all your line level stuff to the motu and save the DM inputs for mics. Once you have the 3 tidf lines hooked up the motu just becomes more inputs into the DM and you should be able to route between the two freely. Monitors should go into the mixer btw
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 08-05-2008
roryo roryo is offline
Newbie
roryo is on a distinguished road
tascam and apple help
hi... newbi here. i have been doing a little recording for a while and i am buying in a lot of new equipment and i need a bit of advise. i wish to buy a tascam dm3200 mixer to run with an apple pro. what is the tascam dm3200 like for starters. what are the ,mic pre's and EQ like, and does it require alot of processing power?? the apple pro, now is this computer worth the money or could i build a computer just as good for less?? im not exactly on a tight budget but with in reason.
FS: TASCAM 34B New-In-Box! cjacek Free Ads for Music / Recording Equipment 33 12-13-2007 05:02
Is it true about the Tascam bbs forum? philboyd studge TASCAM User Forum 61 01-06-2006 18:42
Pro Tools Digi 001 OR Tascam 2488 sevendustweb Digital Recording & Computers 3 10-21-2005 16:06
Pro Tools Digi 001 OR Tascam 2488 sevendustweb Newbies 5 10-21-2005 15:37
Mackie into Tascam problem SouthSIDE Glen Recording Techniques 2 04-27-2005 19:35
