Old 06-21-2006
wp001 wp001 is offline
Junior Member
wp001 has a reputation beyond reputewp001 has a reputation beyond reputewp001 has a reputation beyond reputewp001 has a reputation beyond reputewp001 has a reputation beyond reputewp001 has a reputation beyond reputewp001 has a reputation beyond reputewp001 has a reputation beyond reputewp001 has a reputation beyond reputewp001 has a reputation beyond reputewp001 has a reputation beyond repute
were are my aux sends and returns... soundcraft
hey i just bought a soundcraft spirit studio (16channal discontinued) im trying to send my to my out board compressor and i use INS for sends and then AUX-1 to return but i have no controll on the volume or anything its just being sent and dosnt seem to be returning.? n/m i found my sends now what are my returns????
Old 06-21-2006
bennychico11's Avatar
bennychico11 bennychico11 is online now
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
first, usually a compressor is used as an insert, not an aux send
however, returns will probably be located in the master section of the mixer
www.redlabaudio.com
Old 06-21-2006
Junior Member
okay so i go from "insert" form whatever channal i want into "input" on my compreesor then back into the board via were?
Old 06-21-2006
you use an insert cable, which is a Y cable.
Inserts send signal out a TRS end of a cable (along the tip) to a TS end. Then back out another TS end which returns to the Ring of the TRS end. Inserts come back in at the same point they left in the mixer.
The reason you want to generally use inserts instead of auxes for dynamic based effects is because inserts replace the signal you originally had, while auxes just blend wet and dry signal together. You don't want to EQ or compress a signal and then just lay it back on top the old signal...what was the whole point of you EQ/compressing it then!
Auxes are generally used for time based effects...like reverbs.
*note I said 'usually'...feel free to break the rules if you want to hear how it sounds.
www.redlabaudio.com
Old 06-21-2006
Junior Member
ok well thats problem for me at this point becuase i do not have any Y cables handy. how else would i be able to connect my compressor?(thats why i was thinking aux send/return) untill i get some more Y cables.
Old 06-22-2006
Junior Member
arg how can i do this.....
Old 06-22-2006
you can use the aux sends then...but I'd recommend turning down the channel that has the dry signal on it and just using the aux returns for that track.
or you can patch the main output into the compressors and return that somewhere else (like a soundcard or whereve you're recording to)...but I'm sure you want to utilize the main outs for the monitors, right?
www.redlabaudio.com
Soundtracs Topaz Project 8 Nick The Man Other Equipment and Reviews 30 04-08-2008 14:02
Gating and Feedbacking the sends and returns walters Recording Techniques 1 05-01-2005 12:41
DM 24 external effects? fraserhutch TASCAM User Forum 1 12-08-2004 13:46
Difference between SEND and INSERT in cubase Gabriel Sousa Digital Recording & Computers 4 01-27-2003 12:48
