Old 06-20-2006
Joepie's Avatar
Joepie Joepie is offline
Senior Member
Joepie has a reputation beyond reputeJoepie has a reputation beyond reputeJoepie has a reputation beyond reputeJoepie has a reputation beyond reputeJoepie has a reputation beyond reputeJoepie has a reputation beyond reputeJoepie has a reputation beyond reputeJoepie has a reputation beyond reputeJoepie has a reputation beyond reputeJoepie has a reputation beyond reputeJoepie has a reputation beyond repute
Using 30-year old speakers as monitors?
Hi all,
this is the situation: Uptill now I have been using a simple, cheap, AIWA home stereo system for monitoring. The results were... well... OK, but only by going back and forth between them and two other stereos in my house to check my mixes.
I was at my parent's house a while back, and my dad has a set of Kef Cresta speakers from the mid '70's. He assured me that back in the day they were the best money could buy, and they were especially designed for high-dynamic music, like classical stuff. This makes me think they have a relatively flat frequency response... at least not the 'disco smile' that my current setup has.
Do you guys think it'd be possible to use his old speakers as monitors? Keep in mind that I'm in college and have no money whatsoever to buy any new gear. Let me know what you guys think about these speakers. Any info would be appreciated.
Thanks in advance,
Joepie
Old 06-20-2006
NegadivOne's Avatar
NegadivOne NegadivOne is offline
Alchemy slut
NegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond repute
I started mixing on some bose speakers from the 80's and they werent too bad. The should work fine, it really doesnt matter if they are "studio monitors", you can mix on pretty much any speakers as long as you are comfortable with them and know what music should sound like on them.
THATS RIGHT! MUSIC!!!
My Music Myspace
Old 06-20-2006
hrwmusic's Avatar
hrwmusic hrwmusic is offline
Your mo-o-ovin' so fast..
hrwmusic has a reputation beyond reputehrwmusic has a reputation beyond reputehrwmusic has a reputation beyond reputehrwmusic has a reputation beyond reputehrwmusic has a reputation beyond reputehrwmusic has a reputation beyond reputehrwmusic has a reputation beyond reputehrwmusic has a reputation beyond reputehrwmusic has a reputation beyond reputehrwmusic has a reputation beyond reputehrwmusic has a reputation beyond repute
id go for it. But get more accustomed to them first by comparing what you usually listen to through both speakers. It's important to get used to them, and learn what they might add, or take away. Also, google the speakers and you may find the frequency reasponse .
Harrison Weber
Acoustic Music for the Independent Mind, Body, and Heart.
Samples At PureVolume.com
Sweet free audio editer/multitrack recorder: "Reaper"
Old 06-20-2006
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
I'd be concerned with the condition of the drivers and foam after all those years. For example, if the foam edges of the woofers have deteriorated, the low-end response would not be the same as brand new ones of the same kind.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 06-20-2006
Joepie's Avatar
Senior Member
Thanks for the responses.
@ MadAudio:
I looked at the speaker cones through the grille, with a flashlight, and they seem to be in good condition. At least no visible deterioration of any kind... does that mean they're ok, or would that kind of damage not be visible anyways?
Old 06-20-2006
MadAudio's Avatar
Damned if I do
@ MadAudio:
You can't always tell from a visual inspection. I'd just try hooking them up and cranking them up slowly. If they don't get farty in the low end, they're probably OK.
Old 06-20-2006
Joepie's Avatar
Senior Member
Well, I just hooked em up to the old amp that came with em (same era, Solid State amp, brand called Lafayette...) and they sound pretty good. They're a lot clearer than the hifi speakers I'm using now. Especially the highs sound a lot better.
No bass-problems, except when I turn up the bass on the Amp EQ (2-band EQ, woohoo!). I'm thinking it's the amp that's cracking up though, not the speakers. It makes the same noise when you turn the volume knob. Also, when the EQ is set to level, and playing at 'monitoring volume' the problem doesn't occur.
Looks like I got a new pair of monitors! Although the term 'new' might not be appropriate, haha.
Old 06-20-2006
suntzu1982's Avatar
suntzu1982 suntzu1982 is offline
You got to funkafize.
suntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond repute
speaking of 30 yr old monitors...has anyone heard of UA300 series?
I'm in the same situation, my dad's old speakers. The funny thing is they say, "Studio Monitors" on them. So I'm sure if they are made for monitoring or music enjoyment. I don't even know if 'UA' represents the company or not.
"Blindness and deafness are not only physical conditions; they also exist in knowledge."
Old 06-20-2006
MadAudio's Avatar
Damned if I do
Yeah, that sounds like a dirty volume pot, and given the age of the amp that's no surprise.
Congrats!
Old 06-20-2006
sjjohnston's Avatar
sjjohnston sjjohnston is offline
Force of Nature
sjjohnston has a spectacular aura aboutsjjohnston has a spectacular aura aboutsjjohnston has a spectacular aura about
They probably weren't quite the best money could buy, but they were (and, I think, still are) pretty good speakers.
I think "Cresta" was a line, rather than a single model. Anyway, there was more than one version.
Speakers should definitely last that long. Particularly (as is likely) they were well-kept in a house, and not moved around, dropped, exposed to extreme temperatures, etc. People still use (indeed, regard as "vintage") some guitar amp speakers a lot older than that, and they almost all have been abused, often very much.
Old 06-20-2006
Joepie's Avatar
Senior Member
I went to the KEF website, and they mention the Cresta-series in their 'history' section. The speakers in the pictures don't look like the ones I have though, so I guess there must've been different versions, even in the 70's. I'm sure they weren't the 'best', but my dad said they were definately high-end speakers in their time. I think they sound great to be honest.
Any tips on how to treat these to make them last? Besides of course not dropping them, putting them outside in the rain, etc etc...
  #12
Old 06-20-2006
Kiauma Kiauma is offline
Senior Member
Kiauma is just really niceKiauma is just really niceKiauma is just really niceKiauma is just really nice
The final test, as so many have said here, is in the listen. How do they sound?
One caution though, I do have some familiarity with vintage gear and you should be aware that early transistor amps were, for the most part, pretty crappy. The simple fact is the technology was fairly new, and really didn't have all the bugs out. Early transistor amps are famous for bad harmonics, for example. Lafayette was a decent brand though, at the time.
If you can, try a few other amps of more modern vintage. Just a regular old stereo will do, though I understand if you just don't have any options - just somehting to keep in mind if you get a chance.
Your Aiwa amp may not help either, as the speakers and amp are undoubtedly matched to compensate for each others weaknesses - but it may be worth a try.
Clean out your controls by opening the bottom panel and shooting some control cleaner in the control (there is usually a small hole near where the wires connect - the cleaner usually comes with a small tube you can stick in the nozzle to reach tight places) while turning the knob from one end to the next a few times. You can get it at radio shack.
  #13
Old 06-21-2006
giraffe's Avatar
giraffe giraffe is offline
i love negative rep
giraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond repute
my second pair of monitors are some mission 770's
they were the bomb in the 80's!!!!!!!!
i've replaced both woofers (cause i blew one)
but mostly they help because the freq response goes much lower than my tannoy reveals.
audio?
seriously, give me negative rep.
  #14
Old 06-22-2006
talontsiawd talontsiawd is offline
Dedicated Member
talontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond repute
I used some decent hi fi 70's stuff for awhile. It wasn't ideal but it worked. My mixes were pretty much hit or miss. They didn't have the mids i needed. But they had better lowend than my moniters and decent highs. But way better than headphones or computer speakers, which i found to be about the same. I'd put my hi fi stuff between my moniters and my headphones. I have krk's too which people don't concider to be great. I'd actually still have them hooked up if my amp didn't blow. Just for some sort of reference, even though subjective and not real world- different speakers, it will give you a clue.
EV SX500+ speakers as studio monitors? RMadness Mixing / Mastering 33 03-07-2006 09:10
Little Speakers being used as stage monitors sindawg Other Equipment and Reviews 11 03-05-2006 20:39
Computer Speakers vs. Monitors aposynthesi Other Equipment and Reviews 3 10-31-2003 13:56
Question about monitors / pc speakers ticker Digital Recording & Computers 6 06-05-2003 23:56
is there a real difference between stage monitors and standard speakers? pchorman Other Equipment and Reviews 12 08-29-2002 00:05
