Old 06-20-2006
Ced's Avatar
Ced Ced is offline
Still a Newbie
Ced has a reputation beyond reputeCed has a reputation beyond reputeCed has a reputation beyond reputeCed has a reputation beyond reputeCed has a reputation beyond reputeCed has a reputation beyond reputeCed has a reputation beyond reputeCed has a reputation beyond reputeCed has a reputation beyond reputeCed has a reputation beyond reputeCed has a reputation beyond repute
Question Starting my personal recording
Hello!
I'm new to this site!
Ok let's start with my situation. I went to a studio to record my band and the technician was using Cubase SX and aaaall his console, mixing, input, mics stuff.. so I know pretty well how the recording process work!
So now I start a acoustic solo project (acoustic guitar & vocal) and I want to record it on my own and add electronical beat too. So I have Cubase SX and Reason to proceed. I just bought good headphones too.
I record a draft of my song with Cubase and I'm pretty use to it. I started with Reason and I think that with some tests I will get it better pretty soon.
So for now I recorded my songs with a little Computer microphone, I can't deny it doesn't sound as good as a studio recording but it worked pretty well for that cheap kind of microphone!!
I just want to know what would I need to get the best of my sound ?????
I have in my mind to buy a Shure SM-57 to record the guitar and the vocal better but I don't know if I need something else (mixer, console, input).
My computer is 2.8Ghz, 1Go RAM with an integrated sound card.
What would I need else ???
P.S. I am not too rich so if you have cheap way but it gets a good sound I would be really happy!!!!
Old 06-20-2006
suntzu1982's Avatar
suntzu1982 suntzu1982 is offline
You got to funkafize.
suntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond repute
For people to give you better information, your budget is needed.
There are a million ways to start recording, but you may want to consider one of two methods:
1. Mixerless: This requires an audio interface with built in I/O and preamps. A really good deal right now is: Firepod + 3 Mics + Shock Mount + Cords
I just bought it, because it seems for beginning a studio this is a good piece of equipment to start with.
2. Mixer/Soundcard: You could also buy a sound card (the one on your computer isn't really built for recording), and then a mixer for the I/O. Since I did not go this approach, I can't help too much. It seems many people go M-Audio, so check there site out.
Alex
"Blindness and deafness are not only physical conditions; they also exist in knowledge."
Old 06-20-2006
Ed Dixon Ed Dixon is offline
1K Silver Member
Ed Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond repute
There is a third option. Buy a small digital recorder, like a Fostex MR8. Use it to record the tracks one or two at a time. Import to PC via USB and mix there.
One advantage to this is the fact that recording can be done somewhere other than the PC room, which might be noisy. Find the room where recording works best, do it there, then mix at PC. I use this approach and it works very well.
Ed
Old 06-20-2006
Ced's Avatar
Ced Ced is offline
Still a Newbie
Thanks for your fast reply Alex! really useful!
I would probably go for the Mixer/soundcard method!
Do someone knows which Soundcard and which Mixer should I buy for the purpose of my project ???
I don't need many inputs - only two would be enough because I will record track by track - means acoustic guitar then vocal and then I will add electronical effects.
Thank you.
PS I will check for the M-Audio, thanks again!
Old 06-20-2006
Ced's Avatar
Ced Ced is offline
Still a Newbie
And I would like to know also if SM57 would be a good asset to record the guitar and the vocal!
Old 06-20-2006
suntzu1982's Avatar
I've read that it is a good versatile mic, that has a bass proximity effect (meaning, the bass is accentuated as you go closer to the mic). Especially good for both guitar and vocals. ALthough for specifically vocals I hear shure SM58 is good.
Old 06-20-2006
1K Silver Member
I have both 57 and 58 models, which are both good. For vocals I normally use a small battery powered condensor mic, which works very well.
The key thing for both vocals and acoustic guitar is room enviroment. You want zero noize and no cars driving by. If you use a mic stand, place on carpet. Avoid standing on hard wood floors, as slightest movement can be heard.
A good check of your room is to set up to record, and record just the room itself. Listen to hear what makes it through. I may surprise you. Birds chirping outside, A/C units coming on/off, ticking clocks 20 feet away.
Ed
Old 06-20-2006
Ced's Avatar
Ced Ced is offline
Still a Newbie
Good thank you very much for the mic's hint!
I also would like your advice about the soundcard and the mixer I should use with a good ratio quality/price ????
I don't need many inputs on the mixer - only two would be enough because I will record track by track - means acoustic guitar then vocal and then I will add electronical effects.
Ced
Old 06-20-2006
sixways sixways is offline
Force of Nature
sixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond repute
If I were you, I'd get a M-Audio Mobile pre. Buy it here, and you also get 2 condenser mics for free.
http://www.musiciansfriend.com/produ...ace?sku=701368
I just recommended the exact thing for a friend here, and its ideal for what you are wanting to do. Costs $149.00.
Get two mic stands and two mic cords, and you're good to go.
6
Old 06-20-2006
Ced's Avatar
Ced Ced is offline
Still a Newbie
Oh yeah! it looks great!! I will keep this in my mind and waiting for some other proposition but it took the first place!!!
Thanks to you sixways!! My choice will probably be that!!
Any other propositions???
Old 06-20-2006
pandamonk's Avatar
pandamonk pandamonk is offline
Three Thousand and Counting
pandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond repute
I was gonna recommend you check out a thrad i just posted a suggestion in, but that deal is a lot better.
  #12
Old 06-21-2006
Ced's Avatar
Ced Ced is offline
Still a Newbie
Talking
Ok then! I saw that it was the best deal I could find for what I want to do so I finally bought it after checked all deals.
Thank you very much for this ad
Ced
  #13
Old 06-21-2006
Markaholic's Avatar
Markaholic Markaholic is offline
More Me In the Monitors!
Markaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond reputeMarkaholic has a reputation beyond repute
you have a intergrated soundcard and a crappy mic and yet you bought 1000 bucks worth of software w/o knowing what should go w/ it?
Sorry but..im surprised no-one else thought this too..you guys are slipping!
  #14
Old 06-21-2006
Ced's Avatar
Ced Ced is offline
Still a Newbie
:P
I got those software from the guy where I recorded a demo for my band! He was a friend of mine!
  #15
Old 06-21-2006
Mindset's Avatar
Mindset Mindset is offline
Mindset Music Group
Mindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond repute
if I was you I would be saving up and getting better equipment. when I first bought equipment for recording, I didn't just jump on a all-in-one solution. I knew it would be a process in getting an almost-ideal set up. I am still far from it, but I, myself, had to get piece by piece to get something set up. I suggest first you get yourself a good recording sound card, some outboard gear, some mic's and get started.
VOTE MMG @ 2010 SOUTHERN ENT. AWARDS NOW EASIER BY VISITING
MMG VOTING SITE
Check our Myspace!
  #16
Old 07-07-2006
singinsolo singinsolo is offline
Newbie
singinsolo is on a distinguished road
Compare MobilePre and Fast Track
I'm only doing acoustic guitar and vocals. Which would work best for me? Does the MobilePre have any advantages that would justify the extra $50? My budget is very tight, so want to get the most for the least first time out.
Also, Musician's Friend has a refurb Fast Track for a little less. has anybody tried it? As good as New?
Thanks
Singinsolo
Can I get advice from those who have a home studio? Chrisku13 Studio Building & Display 56 08-21-2006 23:20
Question about recording wolf70 Recording Techniques 8 06-06-2006 19:14
Punch-in Style Compression BRIEFCASEMANX Mixing / Mastering 39 05-18-2005 14:53
THE DAVEMANIA COLLECTION Glorifies HOME RECORDING and GUITAR/BASS MUSIC! A Reel Person Guitars and Basses 5 12-15-2001 14:56
