Go Back   Home Recording > User Forums by Brand > n-track User Forum
     Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 06-19-2006
futbol1097 futbol1097 is offline
Newbie
futbol1097 is just really nicefutbol1097 is just really nicefutbol1097 is just really nicefutbol1097 is just really nicefutbol1097 is just really nice
Record / Playback configuration - newbie ?
A newbie here - just purchased N-Track upon realizing that my previous software which did not support ASIO drivers was the reason for the severe latency problem I was experiencing. I record with a Tascam US-122 Audio/MIDI interface, and I went with N-Track for its ASIO support (and low price tag, obviously) because I want to use the Direct Monitor feature of the Tascam. I'm trying to figure out how to set-up my "Recording" and "Playback" sound card options to enable this feature. Basically I want to disable input monitoring altogether through my computer's sound card and directly monitor tracking through my Tascam US-122, and the "direct monitoring" control. So when I am overdubbing tracks I would be able to listen to the other tracks through the headphones plugged into the Tascam and record with no latency. Can anyone help me with configuring N-Track 4.2.1 to support this control?
My recording & playback options are: (SigmaTel is my computer soundcard)
Audio Playback Devices:
ASIO US-122 (16 bit)
ASIO US-122 (24 bit)
MME: SigmaTel Audio
MME: US-122 Out
MME: Wave Mapper
WDM: SigmaTel Audio
1-WDM: US-122 Out
Audio Recording Devices:
MME: SigmaTel Audio
MME: US-122 Out
MME: Wave Mapper
WDM: SigmaTel Audio
1-WDM: US-122 Out
Which options do I select in order to record with the US-122? Just ASIO, or do I select more than one? Also, Tascam customer support said that in order for the Direct Monitor control to work, I also need to set my MIDI ports (both MIDI In and MIDI Out) to the US-122. Where is this option available?
Any advice would be greatly appreciated guys.
Thanks for the help,
E
Old 06-19-2006
suntzu1982's Avatar
suntzu1982 suntzu1982 is offline
You got to funkafize.
suntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond reputesuntzu1982 has a reputation beyond repute
I haven't used n-track extensively, and I'm pretty new to recording. However, I believe, from using my firepod, that you need to use the AISO settings for both. Really, you should just try them all and see which work, but through Cubase I use AISO.
Alex
"Blindness and deafness are not only physical conditions; they also exist in knowledge."
can any vf160 users explain BUSS recording? getupkid0717 Fostex Forum 2 07-26-2005 21:46
HS 2004 record and playback problem VooDu Valve Cakewalk / Sonar Forum 1 07-04-2004 05:51
Matching Record and Playback Output? bongolation Cubase User Forum 6 03-04-2002 07:38
How to Record and Playback Simultaneously on My Computer? eb Newbies 6 04-18-2000 20:27
Newbie needs to record voice for RealAudio ParadiseCowgirl Newbies 2 07-28-1999 21:58
