FS 1 truth audio TA-1P(not behri truth)monitor
I had originally bought the extra one with the intent to do surround , but now ive decided to focus on strictly 2ch. I have B+W 802s, and the truths, and I will never sell my truths. They are absolutely true to the source and translate VERY well. they go for 1000 a pair, but I will sell this one for 230(shipped). You can easily find a mate on ebay or elsewhere. Positive reviews abound for these monitors..mint condition..
http://www.truthaudio.com/ta1p.htm Each TA-1P cabinet consists of 2-5 inch mineral-filled polycone woofers with a 14.6 ounce magnet and 1- 1 inch tuned chamber cloth dome dynamic tweeter offering a frequency response of 48Hz to 20kHz. These cabinets have a unique rear bass port producing more low end than most sub systems. The mid range in the TA-1P sets it apart from any other near-field. Absolutely the best imaging and clarity in the mids anyone has ever heard. The patented crossover design took two years to develop, but our engineers are now satisfied. You will hear why it was worth the wait. The power handling capability is rated at 160 watts continuous power into 4 ohms. All rear panel connectors are gold plated . Do yourself a favor and hear the Truth. TA-1P SPECS AS LISTED Frequency Range -6db (48HZ-24KHZ) Frequency Range + / -2db (51 HZ-22KHZ) Sensitivity 90db SPL 1W (2.83V) 1m Power Rating: 80 watts, nominal 140 watts, Music Nominal Impedance 4 ohms 160 watts Continuous Music into 4 ohms Minimum Impedance 3.4 ohms @ 150HZ Crossover Frequency 2KHZ Dual 130 mm Woofers (Mineral Filled Cone Fitted Pole Piece) 25mm Diameter Voice Coil Magnetic Assembly Weight .415kg BL Factor 6.0 TELSA/METERS Moving Mass 7.5g X-Max 4mm Sensitivity 88dB 2.83V / 1M 27mm Coated Sonotex Cloth Dome Tweeter Magnetic Fluid Filled, Vented Pole Piece with Rear Chamber Diameter 27mm Voice Coil Diameter 26mm Magnetic Assembly Weight .25kg Force Factor 3.5 N/A Sensitivity 91dB 2.83V / 1M Cabinet 3/4 Inch Maximum Density Fiber Board (Cabinet) 1 Inch Maximum Density Fiber Board (Front Panel) Finish (Vacuum Sealed Vinyl) 10 Inches High / 14.5 Inches Wide / 10 Inches Deep Cabinet Weight: 21 lbs. All Connectors are Gold Plated |
FWIW, I am one of the good guys(buying and selling wise..am a dickhead in real life)
Teddy |
I can vouch (or at least agree with BigRay) that the truth audio monitors are a beautiful thing. Someone should snag this....
Dealer for Peluso Microphones, Blue Microphones and CBI cables.... http://www.myspace.com/xstaticstudios |
wow, Xstatic agreed with me. Mazeltov!
Yes, they are fantastic..ive auditioned many monitors from 1,000 to 10-12,000 and these have stuck.... |
| How to use Waves X-Noise (noise reduction) properly? | quietb03 | Mixing / Mastering | 3 | 07-27-2006 17:11 |
| Wavelab 6!next month... | BigRay | Other Equipment and Reviews | 3 | 01-22-2006 12:13 |
| Audio Driver Quality | Kaydis | Mixing / Mastering | 0 | 05-03-2001 19:32 |
| Audio speed/pitch problem in Cakewalk Pro Audio 9 | humbuckerdave | Cakewalk / Sonar Forum | 1 | 03-23-2001 16:41 |
| PC DAW Digest | TAE | Digital Recording & Computers | 0 | 11-25-2000 09:03 |
