Old 12-17-2000
creaturebeats creaturebeats is offline
Newbie
creaturebeats is on a distinguished road
Question
For some reason in cakewalk 9.0 when i assign "gigasamper endless wave" as my MIDI output port it does not play back any of my old .WAV audio files that i already have in a cakewalk .WRK file but when i switch back to my default MIDI output port (MIDI out delta-1010) all my old audio files play but i don't have access to the gigasampler sounds.
Why is that?
this is a quote i got from cakewalk.
"If you intend to record or play audio in Pro Audio and use Gigasampler LE simultaneously, you must have a soundcard with two audio outputs or two soundcards each with one audio output. This is because both Pro Audio and Gigasampler require exclusive use of a stereo audio output driver"
I have 2 soundcards. The Delta-1010 and the MOTU 2408 both are gigasampler compatible. I have the latest drivers for both.
If anyone can shead some light on this for me because i really wanna to use Gigasampler with Cakewalk but i still wanna be able to use audio files in my mix.
thankz
Old 12-18-2000
kennedy connor kennedy connor is offline
Senior Member
kennedy connor is on a distinguished road
it should work but there are a few possible problems...I'm no expert but i had this situation when i had 2 cards. Make sure in the hardware routing in giga that it shows the appropriate card. Make sure it isn't the same one as cakewalk... I never did get mine to see the new card but it may be necessary to reinstall giga... that might do the trick. Make sure that nemesys has given you the latest updates/patch. this made the difference for me also I bought a multiclient card [the soundscape mixtreme] and took out the other card. Contact nemesys and also check out the giga forums at northern sound and Sonic control... there are los of users with exotic setups who may be able to give you more specific answers...also robinv the pc music guru runs multiple cards and everything but the kitchen sink on one pc.....giga has taught me alot about patience!
Good luck
Old 12-18-2000
Newbie
how do i get in touch with robinv the pc music guru
and thanks for your advice but even if i enable 1 sound card in giga and the other in cake when i switch to endless wave none of my soundcards work except for any audio comming from gigasampler. I also go the latest drivers.
Old 12-18-2000
Newbie
http://www.northernsounds.com/ubb/No...ML/000960.html
that's the link for the answer to my problem.
thanks for the tip man.
