Old 06-15-2006
Bill Furnett Bill Furnett is offline
Senior Member
Bill Furnett has a reputation beyond reputeBill Furnett has a reputation beyond reputeBill Furnett has a reputation beyond reputeBill Furnett has a reputation beyond reputeBill Furnett has a reputation beyond reputeBill Furnett has a reputation beyond reputeBill Furnett has a reputation beyond reputeBill Furnett has a reputation beyond reputeBill Furnett has a reputation beyond reputeBill Furnett has a reputation beyond reputeBill Furnett has a reputation beyond repute
Air gap treatment advice
Hey gang,
I’m doing a 1st time home-studio (attic) build that will eventually feature 3 simple booths and a control room.
Naturally I have thousands of questions on as many facets of design and construction, but today my focus is on the drum booth.
It seems my best defense in the war on noise will be double wall construction
(double 5/8 drywall – stud – 703 in the gap – then another double 5/8 – air space – then another wall of the same.) , but each wall will have a double pane window in it.
I know the windows are less than ideal from a leakage / reflective surface stand point, but this concession must be made in order to have visual contact with the drummer.
Today’s questions:
How would I treat the surface of the two walls on either side of the air gap?
(Will I absorb, diffuse, both, or neither in that space?)
I know it’s vague and a great many variables would affect an appropriate answer, but in general what does sound tend to do between two close walls of this construction type and how might I best tame the ill effects?
Been a few years -Great to be back on HR.com
-Billy-
Old 06-15-2006
tsl92802 tsl92802 is offline
The Boomer
tsl92802 is just really nicetsl92802 is just really nicetsl92802 is just really nicetsl92802 is just really nice
I had the same type of issue actually. I found a place that sound a close circuit camera for about $40 (Harbor Freight Tools I believe is the name of the place). Hooked that up to a cheap little tv, and it actually has a little mic on it for talk back, night vision if your drummer decided that having only one candle lit in the room will make him play better, etc. It was cool, easy to install, the cables ran like 200ft or something stupid like that...great deal, worked well, very happy, WAY cheaper than two pane windows, and MUCH less leakage. Good luck!
Old 06-15-2006
gummblefish's Avatar
gummblefish gummblefish is offline
Twitchy Wanker
gummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond reputegummblefish has a reputation beyond repute
Im only gonna chime in on the window issue. This might not work for everybody, but one way i got around that issue in my last place was to use a television monitor on the wall hooked up to a cctv camera or even a video camera. Then do the same for your control room. I think it adds a bit of charm as well.
"Sorry wont Suture My Colon"
Old 06-15-2006
Twitchy Wanker
Damn you got there before me
Old 06-15-2006
Ethan Winer's Avatar
Ethan Winer Ethan Winer is offline
Why 2K?
Ethan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond repute
Lightbulb
Bill,
> Will I absorb, diffuse, both, or neither in that space? <
Small rooms benefit most from absorption.
--Ethan
The acoustic treatment experts
Old 06-15-2006
Senior Member
Thanks for the responses guys.
I think I will try the density and absorption route (windows be damned) 1st and see just how bad it is. I can always pull the windows out and “solidify” the walls if it seems it’ll make that much of a difference.
The windows (Double paned 24 x 50) I was lucky enough to find just as they were being pitched in a remodel, so by some divine home studio building right, no added expense there.
On cams– I plan to do web type cams (one in each booth– two in the control room) that feed into a computer in a cove in the adjacent "chill room".
This is an experimental attempt to render the tagalong wives,husbands, boyfriends and girlfriends completely useful and creatively part of the team as they can monitor, capture and eventually edit together a simple ‘Making of..’ or in studio video.
Just frivolous icing, but I love icing!
-Thanks again-
Old 06-15-2006
Twitchy Wanker
Yeah, yeah thats what everyone does at first. Then the depravity begins, soon your on the road to pornsville next stop prison.
Old 06-15-2006
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
Uh oh, that's four leaves . . . Rick won't like that! Omit the inner pairs of drywall.
Also, you don't need to use 703 inside the wall, regular ol' roll insulation works fine with less work and waste.
Old 06-15-2006
Senior Member
Omit the inner pairs you say?
Too much density begins to reflect huh?
Thanks guys
-Porn is simply nature's way of saying, "Whoa, look at the *&%@ on her!"-
Old 06-15-2006
Faithful Departed
No, I believe it's a matter of creating a resonant structure. Rick has a clever picture that he posted that shows the STC of various wall constructions, lemme see if I can find it.
Edit: here it is:
Old 06-15-2006
Senior Member
Beautiful. That's the info i was looking for.
Thanks MS
  #12
Old 06-17-2006
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
I don't think you need to worry about 703 in the airspace either. Save it for the interior wall absorbers. You can use regular insulation inside the airspace.
  #13
Old 06-17-2006
studiomaster's Avatar
studiomaster studiomaster is offline
MachWave
studiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond repute
Make sure you add bass traps.
  #14
Old 06-19-2006
big country's Avatar
big country big country is offline
Senior Member
big country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond repute
before I put dry wall up ,and before I put the intstalation in I hung a bunch of
roofing papper to the walls . I did this to 2 walls in my studio and wish I would
have done all four walls . its cheap its only like fourty dollars a role. and the walls with the tar papper have really low noise on the out side. I put like four
layers of that crap on the walls .cheap but very efective way to sound proof a room.
  #15
Old 06-19-2006
Innovations's Avatar
Innovations Innovations is offline
1K Silver Member
Innovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond repute
That is particularly a good solution if you also need a vapor barrier, but otherwise it is just mass and gypsum board is still cheaper per pound.
Advise on Floor to put in my new studio iwanarock Studio Building & Display 11 06-19-2006 19:06
Advise to buy a guitar amp!!! jmgrosso Guitars and Basses 13 07-07-2004 12:50
Computer as a synth. Please advise zbert Digital Recording & Computers 6 08-18-2003 21:57
advise on studio, please larrye Studio Building & Display 3 11-13-2001 09:59
Need Advise!!!! PRiZ-one Mixing / Mastering 14 09-25-2001 22:05
