Homebrew Electronics Power Screamer
Uses a JRC4558D chip like in the Ibanez Tube Screamer. Unit has a 3 way switch for changing the diodes. This gives sounds like a Tube Screamer (but without the midrange hump and with more clarity), a Boss SD-1, and something that is a bit different, than either. There is also a boost switch, which also adds highs for cutting through during solos. Altogether there are 6 distinct overdrive tones. I modified the gain control using an audio taper pot, as suggested by the maker. Now there is a more gradual increase in gain across the entire range of gain, which allows greater control. In very good condition, although there are two very tiny paint chips (beauty marks )that you can see in the picture. One is near the top rioght hand side, the other is near the on-off switch on the right hand side. It was difficult to photograph the pedal because it has a red metal flake type paint job. The metal flakes make it look a bit funny. Harmony Central Power Screamer $100 + shipping. |
| All the World's Tube Microphones PART ONE | Bambi Busboom | Microphones | 2 | 08-15-2004 04:02 |
| pulling power tubes ----> 50% power | gusfinley | Guitars and Basses | 1 | 06-24-2004 08:21 |
| Negative dB numbers | Jack Hammer | The Rack | 25 | 08-06-2002 20:45 |
| Help!! - Double Phantom Power ?? | Carlos | Microphones | 13 | 05-26-2000 09:42 |
