Old 06-10-2006
wilko's Avatar
wilko wilko is offline
In the doghouse
wilko has a reputation beyond reputewilko has a reputation beyond reputewilko has a reputation beyond reputewilko has a reputation beyond reputewilko has a reputation beyond reputewilko has a reputation beyond reputewilko has a reputation beyond reputewilko has a reputation beyond reputewilko has a reputation beyond reputewilko has a reputation beyond reputewilko has a reputation beyond repute
MR-8 Problem - any ideas?
I am a reasonbly experienced MR-8 user. I have just plugged my guitar in to both inputs and armed tracks 1 and 2. 2 comes out but track 1 does not. I have played with the input levels and still nothing. I armed tracks 3 and 4. 4 comes out but three does not. I armed tracks 5/6 - 6 comes out, 5 does not and same on tracks 7 and 8. I tried the balanced input with a mike, still nothing. I have changed leads on all combinations. I have a feeling it is just broken. Any ideas or is it straight to the shop? It is also out of warranty wouldn't ya know!
Old 06-11-2006
JoeyPazera's Avatar
JoeyPazera JoeyPazera is offline
Senior Member
JoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond repute
Im almost posotive its gonna be a problem with something other than the MR-8, if it does the same thing over like taht
Pearl SMX Green Burst
10, 12, 13, 16, 22
Pearl Steel Picillo 13 x 3
Zildjian A and K customs
Alesis MultiMix 16
M-AUDIO BX8a's
Old 06-11-2006
wilko's Avatar
In the doghouse
Ok - any ideas? I have been using it for over 2 years and I thought I had it sussed. I have changed the leads.. everything I can think of.....but if you have any suggestions, I'd be grateful!!!
Old 06-12-2006
digitcallous digitcallous is offline
Senior Member
digitcallous is on a distinguished road
I thought you HAVE to used tracks 5/6 or 7/8 for 2 track simultaneous recording. I have a habit of doing it this way so I don't even remember if that's what I have to do.
My suggestions are to check:
- input trim knob to make sure you are allowing the proper input levels on each channel
- slider switch is up (if you are using 5/6 or 7/8 obviously there is only 1 slider)
- play something and look at the LCD display to see if you see the volume bars moving on the channels you are trying to record to
DC
Old 06-12-2006
wilko's Avatar
In the doghouse
DC
No you don't have to use those. I frequently use tracks 1 and 2 for stereo guitars.
Yep, I have tried all your suggestions. Even using tracks 5 and 6, I see the level bars move on track 6 but not track 5.
I am positive now it is fried in some way.
Old 06-13-2006
Gorty Gorty is offline
Gorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond reputeGorty has a reputation beyond repute
Just a shot in the dark but is the "Input A Select" switch on the back set in the middle to guitar????
"Gorty's Tunes"
Old 06-13-2006
If you select tracks 1 and 2 but plug into Input A doesn't that record to tracks that are odd, eg 1,3,5 or 7 of your selected tracks, and if you plug into Input B doesn't that record onto tracks 2,4,6 or 8 of your selected tracks.
I'm just shooting wildly here trying to help!!??
Check through pages 29-34 of your Manual!!
"Gorty's Tunes"
Old 06-13-2006
Aha............After reading through the manual it is possible the "Input A" could be faulty because that is the input that controls the odd numbered tracks!!
Try to record onto just one track, in particular an odd numbered track and use Input A only....just to check that you can at least record to your odd numbered tracks in mono. If nothing happens just using Input A when you try to record to just a mono track, I would suggest your Input A is dodgy!
Once again....Just trying to help!!!
"Gorty's Tunes"
Old 06-13-2006
wilko's Avatar
In the doghouse
Hmmmn.. That is one thing I have not checked...... I will give it a go.
Old 06-13-2006
I have a feeling it may be the above!!!????
"Gorty's Tunes"
Old 06-13-2006
wilko's Avatar
In the doghouse
D'oh!! I have discovered what it was and I am feeling rather silly! Cheers Gortdude, you got me thinking and I tried what you said to no avail and then I saw what the problem was!!. I had a headphone plug plugged into the right stereo output instead of the right headphone jack. I just didn't see it as there were no headphones plugged !! Duh......It is alright now and I am a happy camper once more!
  #12
Old 06-13-2006
YAAAAAAAAAAAAAAAAAAAAAAAY
"Gorty's Tunes"
clicking and popping... a very common problem... drummersteve Recording Techniques 15 11-12-2005 16:59
Microphone-Recording Problem fahte Digital Recording & Computers 1 10-23-2004 14:19
Microphone Recording Problem fahte Digital Recording & Computers 0 10-23-2004 06:18
Room acoustics problem jcook Mixing / Mastering 3 09-28-2004 10:11
sonar recording problem Waysid Cakewalk / Sonar Forum 3 03-05-2002 16:03
