Go Back   Home Recording > User Forums by Brand > Cool Edit Pro / Adobe Audition Forum
Reply    Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 06-05-2006
RideTheCrash's Avatar
RideTheCrash RideTheCrash is offline
Force of Nature
RideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond repute
dBVU vs. dBFS
This is in regards to the "recording volume" thread. I did a test today. I stuck a mic in front of a fairly constant signal and watched where it peaked. On my board's meters, I set it to peak at just about 0dB.
On my card's software (Delta 1010lt), which has meters on it, it peaked around -18 (dBFS?), and after it recorded in CEP, it peaked around -18 as well. So this sounds about right?
My stuff is in another room and it's usually just me, so I usually just turn some stuff up and go at it. I guess it's funny seeing such a small waveform, makes me question "was this recorded at a good volume?". It's all psychological.
Old 06-05-2006
ikon's Avatar
ikon ikon is offline
I Want To Learn Audio!
ikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond repute
from what i been reading and trying of this myself is dont use your eyes....use your ears
Old 06-05-2006
tarnationsauce2's Avatar
tarnationsauce2 tarnationsauce2 is offline
Welcome to the jungle.
tarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond repute
Yes that sounds about right.
If you do any "boosting" with your board, you'll be going into the headroom where more noise and non-linearities exists.
Trust your ears always, but also trust decades of design and engineering.
Once you add some compression to something that was tracked in the headroom of your console you'll not have as much room to play as you would have if it were tracked at 0dBvu on your board, -18dBfs on your DAW.
This is where it is advantageous to use 24/32-bit recording. Even at -18db in the digital realm, you're still using more than 16-bits. Then once you are in the digital domain, you can change levels without any addition on noise from running into headroom. As digital technically has NO headroom, unless we give it to ourselves by increasing bit depth (24 or 32) and tracking at a lower dB value. In essency, giving yourseld 18dB noise-free digital headroom.
Old 06-05-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Yes, 0dbVU = about -18dbFS
There is probably a zoom control that makes the waveforms look bigger.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 06-05-2006
Force of Nature
Yeah, there are zoom controls, I'll play around with 'em maybe.
Thanks guys.
I record everything dry through my board, no compressors or any of that. Funny how there is nothing past 0dB in digital. My meters on my board go all the way up to +18, and finally "clip".
Old 06-05-2006
Farview's Avatar
Thanks guys.
Do you see why that makes sense? That means that your board has 18db of headroom, so you give yourself 18db of headroom in the digital world. That is the way it was designed.
0dbVU is line level. -18dbFS is line level
Jay Walsh
Old 06-05-2006
Force of Nature
Man, I didn't even realize that. Makes total sense.
Old 06-05-2006
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
And one of the best ways to make your tracks sound "small" is to record them too "big" - Using the 0dBVU = around -18dBFS rule of thumb while tracking is one of the best things you'll ever do for your sound.
As that's the way it was all designed to work. "Getting the levels hot without clipping" is NOT.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 06-06-2006
I have you and Farview to thank for revolutionalizing the way I track.
And opening my eyes to what I should have already thought of.
Though it took me a while before I "got it". LOL
Again, Thanks guys!
Old 06-07-2006
Force of Nature
Okay, another question. This might just be related to me somehow losing decibels from how my stuff is setup, but:
I have a simple shaker track. It peaks around -12dBFS to -18dBFS (max), in Cool Edit. My Delta software meters tell me it peaks around -12dBFS, which is about right. If I send that track out to my board, the signal comes up at -24dBVU.
Shouldn't it be up higher? Or am I looking at this wrong?
Old 06-07-2006
Farview's Avatar
You aren't doing anything wrong. The meters on you mixer are much slower than the ones on the computer. The computer meters measure peak signal, the meters on your board measure average signal. A shaker doesn't have any sustain, just a bunch of transients, the meters on your board are too slow to catch them. Everything is fine.
Jay Walsh
  #12
Old 06-07-2006
Force of Nature
Oh, alright. I remember reading that in other threads now..'cause VU meters measure average volume. Thanks.
  #13
Old 06-07-2006
Try recording triangle some time - You'll get clips that your PEAK meters don't even warn you of.
And your VU meters won't even budge.
  #14
Old 06-07-2006
Force of Nature
What is "triangle"?
  #15
Old 06-07-2006
Farview's Avatar
http://en.wikipedia.org/wiki/Triangle_(instrument)
It is a percussion instrument. It's also that triangular thing you see in old westerns when the farmers wife is calling everyone to dinner. She hits this triangular piece of metal to get everyones attention.
Jay Walsh
  #16
Old 06-07-2006
Force of Nature
Oh yeah, duh, how did that not click in?
I think I played one once in high school.
  #17
Old 06-07-2006
Triangle, cowbell, tambourine -
You can record them all from a block away and they sound like they're right in your ear.
  #18
Old 06-07-2006
Force of Nature
I have a tambourine and a mounted cowbell. I should give 'em a go.
  #19
Old 06-08-2006
Farview's Avatar
When you set the levels on these and most percussion, you need to set the levels in the software and be done with it.
Jay Walsh
  #20
Old 06-12-2006
Eluzion Eluzion is offline
Newbie
Eluzion is on a distinguished road
I been hearing about the dBVU, but how do you record on that, you know I mean? Could somebody just clear that up for me?
  #21
Old 06-12-2006
Have you read anything on this thread...?
  #22
Old 07-05-2006
imetmatthoopes imetmatthoopes is offline
Newbie
imetmatthoopes is on a distinguished road
stupid stuff
ok so first off i dont know what the heck im doing!! i haev a line 6 toneport ux2 or soemthing like that and i've been trying to lay down some tracks with cool edit and when i select my driver it dont work ...i know its powered through the usb but my cousin had it working just on that with sonar ..but i dont understand why it wont work like that on cool edit ..any suggestions?
wes
PS ....im VERY new to this and am horrable with computers to begin with
  #23
Old 07-05-2006
Force of Nature
You might be better asking this as a new topic in the Cool Edit forum.
  #24
Old 08-09-2006
tangerine's Avatar
tangerine tangerine is offline
grumpy bastard
tangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond repute
There is still the potential for ambiguity with RMS amplitude measurements, since some use the RMS value of a full-scale square wave for 0 dBFS (which corresponds with a 0 dBFS peak amplitude measurement), and some use a full-scale sine wave (which corresponds with typical analog RMS measurements).
* In the case of a FS square wave = 0 dBFS, all possible dBFS measurements are negative numbers. A sine wave of larger amplitude than −3 dBFS would be clipping by this convention.
* In the case of a FS sine wave = 0 dBFS, a FS square wave would be at +3 dBFS.
The measured dynamic range of a digital system is the ratio of the full scale signal level to the RMS noise floor. The theoretical dynamic range of a digital system is often derived by the equation
\mathrm{DR} = \mathrm{SNR} = 20 \log_{10}(2^n) \approx 6.02 \cdot n
This comes from a model of quantization noise equivalent to a uniform random fluctuation between two neighboring quantization levels. For instance, 16-bit audio has a quoted dynamic range of 96.33 dB.
To make an equivalent measurement of a system's noise floor, the full-scale square wave convention is used. A signal which fluctuates randomly between two neighboring quantization levels will measure at −96.33 dBFS with this convention.
I give espskully the splats
  #25
Old 08-09-2006
tangerine's Avatar
grumpy bastard
DR = SNR = 20 \log_{10}(2^n) \approx 6.02 . n
clipping question cpc Newbies 34 02-22-2006 15:25
signal chain DBVU question wang191 Digital Recording & Computers 3 08-22-2005 23:37
i should know the answer to this... Phosphene The Rack 9 10-16-2003 19:26
Negative dB numbers Jack Hammer The Rack 25 08-06-2002 20:45
converter specs for all to read tubedude Digital Recording & Computers 41 05-27-2001 00:16
