Old 06-01-2006
Zane1Tsu Zane1Tsu is offline
Junior Member
Zane1Tsu will become famous soon enough
acoustic foam placement.
Unfortunately, due to limited space, I cannot center my monitors on the wall of the room for mixing. They sit about two feet left of center. Unfortunately, due to my significant other, I can't seal acoustic foam to the entire wall. This leads me to a couple of questions.
1: With limited amounts of foam (Aurelex: 2'x4' plus severel more 1'x1' pieces ) should I center the foam behind the wall, or behind the monitors?
2: What is a good way to mount the foam without bonding it to the wall. (She doesn't want me potentially destroying the walls. And if I move, I can remove the foam without tearing it and save it for the next house.) I was thinking of bonding it to cardboard, then nailing it up.
I did a search and didn't see much on this, probably because it's a dumb question, but I'm not much of a handy man....thanx
Old 06-02-2006
bpape's Avatar
bpape bpape is offline
Acoustic Designer - GIK
bpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond repute
Use T-Pins to mount the foam - look at a shop in with the curtains.
I'd do the foam centered between the monitors. And, make sure that you offset the side reflection point panels to account for the difference in centering.
Bryan
I am serious... and don't call me Shirley
GIK Acoustics
Old 06-03-2006
Junior Member
thanx, I'll look into the T-pins.
What do you mean with offsetting the side reflection ...?
Old 06-03-2006
chugheshc chugheshc is offline
Senior Member
chugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond reputechugheshc has a reputation beyond repute
he means, make sure that any panels you put on the walls that are intended to trap the side reflections (sound reflected from walls that are perpendicular to the speakers) take into account that the speakers are not centered -
the speakers that are further from the side wall will need their panels moved forward to where the sound from the speakers would be hitting them.
cheers
C.
home of the cheap
land of the improvised
Old 06-03-2006
Junior Member
Good to know, thanks.
Old 06-03-2006
Sennheisersucks Sennheisersucks is offline
Newbie
Sennheisersucks is on a distinguished road
I've heard talk of velcro, but not much. Not sure if that's better than t-pins, but I have the same prob, so I'm glad this thread is up.
Old 06-03-2006
Senior Member
i got some interesting magnet/mounts - used to attach ceramic tile when
you might want to move it later. I think it would hold up a sheet
of 703, but it would be toough to attach. I used it to attach a frame w/cloth to voer some 703 in a wall acvity.
C<
home of the cheap
Old 06-03-2006
seismetr0n's Avatar
seismetr0n seismetr0n is offline
face melting 6string fury
seismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond reputeseismetr0n has a reputation beyond repute
to mount i used some spray adhesive(elmers).... use a medium amount it it wont harm the walls.. i have used too little and sometimes they will fall off with temp changes..
i just did a quick test for ya and was able to remove one with no harm to the wall
as for placement... it is best to cancel all first reflections.. (ie all reflections that only bounce once between the speakers and your ears)
my technique was to sit in my normal monitoring position, then have someone else (hopefully your significant other would help ya, mine did) move a lil mirror around flat on the walls... every where that you can see your monitors in the mirror is a 'first reflection' point .. attach some foam in those places (dont forget the ceiling) . and you should be good to go..
my room only required a minimum of 7 pieces of foam..
gl
Old 06-03-2006
RICK FITZPATRICK's Avatar
RICK FITZPATRICK RICK FITZPATRICK is offline
Been Here, Posted That
RICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond repute
Unfortunately, when it comes to this type of stuff, significant others are usually MORONS. Do what your gonna do and tell her to fuck off. THEN fix it when you move...otherwise, your a pussywhipped idiot who'll get nowhere with this stuff.
alright breaks over, back on your heads!
Old 06-03-2006
JeffLancaster's Avatar
JeffLancaster JeffLancaster is offline
Dedicated Member
JeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond repute
Love it!
Old 06-05-2006
bpape's Avatar
The only reason I suggested the T Pins is that they'll do the least damage to the wall. Velcro, magnets, etc. require some kind of bonding to the drywall surface that will usually cause minor to major damage when removed.
T Pin holes can easily be removed for changing placement too and only leave a very small hole - no worse than hanging a picture.
- or ditch the wife as Rick suggested...
GIK Acoustics
  #12
Old 06-05-2006
EdWonbass's Avatar
EdWonbass EdWonbass is offline
pull the goalie
EdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond repute
T-pins are the way to go. I used them and it makes the job go faster and it allows for changes in placement.
Make sure you put something over your thumb because it will start to hurt after a about 10 pins or so.
I lost my pants in the fountain.
  #13
Old 06-05-2006
Junior Member
I tried the T-Pins, works great, you guys are awesome. As far as the significant other, the house is in her name. The house I own is shared with my brother and is significantly smaller. So, her house is actually the best option. But if I ever really needed to move things, I could, being that the foam is easily removed. Thanks, again!
Cheap Acoustic Guitar Pickup System Bassman Brad Guitars and Basses 8 08-11-2005 07:52
"Temporary" acoustic foam mounting?? thane1200 Studio Building & Display 14 08-10-2005 10:13
changing the color of acoustic foam ihs221 Studio Building & Display 3 08-16-2004 00:20
The best way to make an acoustic guitar heard live... microphone, pickup, or what? pisces7378 Guitars and Basses 9 03-19-2003 20:07
Mic placement for acoustic guitar: do we overdo it? LI_Slim Recording Techniques 12 03-10-2003 19:44
