Cable Soldering Question
Hello Everyone,
Wasn't quite sure where this one belonged, so I appoligize if I misplaced it. Anyway, I have a roll of 2333 Console Audio Cable by Mogami. It is a single conductor wire surrounded by sheilding. When I solder a 1/4" TS connector to it I first strip the outter plastic casing of the wire and peel back the sheilding. I twist the sheilding together and later solder that to lower and larger surface of the plug. I then strip about 1/4" of the lead wire and twist it. In this smaller wire, there are the metal leads but also these tiny plastic fibers. When I am tinning the lead, these fibers usually melt. My question is...Is this okay? If not, what should I do with them? Hope I was clear enough. Thank you!! Cheers, Scott |
The Plastic strands mixed in with the cable should be cut back to where the jacketing ends and the shield is first revealed. (that rhymes) anyway, take the shield and wind that into itself so that you basically have a thin wire of it about as long as the single conductor wire. Pre tin the sheild all the way back to the jacketing. then cut this down about half its length. this will keep it from seperating then do as you had mentioned above.
Peter Miller |
I have heard both ways now. Cutting them back vs. simply melting them. What are the advantages of cutting them off instead of melting them?
Peter Miller |
I gotcha.
Thanks! |
| cable question | scotsman1 | Newbies | 4 | 01-30-2006 11:55 |
| Microphone cable & impedance question | studiodrum | Microphones | 2 | 01-15-2006 18:41 |
| cable question | freeztar | Other Equipment and Reviews | 2 | 10-16-2003 23:15 |
| A question about cable... | Lame Thrower | Newbies | 4 | 11-23-2001 11:40 |
| Cable Question | Popcorn | Newbies | 21 | 03-11-2001 08:43 |
