Old 06-01-2006
garbagelarge garbagelarge is offline
Junior Member
garbagelarge is on a distinguished road
isolation booth doors
hi - i am renting a space that was built to be a studio. it has a big live room and two isolation booths. we turned one of the booths into a control room. the first acoustical problem that we have encountered is that the booths are not soundproofed - hardley at all. they were poorley designed and i think a lot of the leakage comes from the doors which were constructed of 1/8 plywood on either side of about 4 inches of styraphome. i want to put new doors in and i am looking for a design....
any input or directions to another post(i did search and read some very helpful things) or website would be great -
thank you - ben
Old 06-01-2006
studiomaster's Avatar
studiomaster studiomaster is offline
MachWave
studiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond repute
Design don't matter. Make sure you use a heavy door so it can eliminate any vibrations going in or out of the booth. Also, dampen the door from the booth side with 703 perhaps.
Old 06-01-2006
Junior Member
door design
because the door has to be so thick(4 inches or so) to fit where old one was, i was thinking of having 2 thick sheets of ply-wood with a cavity in the center(created by using 4 2 x 2's at the edges, in between the sheets) stuffed with some type of insulation - will this work and if so what type of insulation should i use?
thanks, ben
Old 06-01-2006
Junior Member
or this...
would i be better off just using solid plywood (it would have to be several sheets screwed together) with absorbtion on the booth side? - thanks
Old 06-01-2006
pandamonk's Avatar
pandamonk pandamonk is offline
Three Thousand and Counting
pandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond repute
Have you considered MDF? It's probably a lot denser so should isolate better.
building a isolation booth..please help... ShellShock Studio Building & Display 89 07-16-2006 23:51
What cables should run into an isolation booth? phatmass Studio Building & Display 13 08-18-2005 21:21
do you use an isolation booth at home? robjh22 Fostex Forum 9 06-12-2004 23:13
do you use isolation booth at home robjh22 Studio Building & Display 1 06-02-2004 08:01
