Old 05-31-2006
studiomaster's Avatar
studiomaster studiomaster is offline
MachWave
studiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond repute
Not getting that adequate monitoring environment...
I use the event tr-8's. their bass response is awesome as well as the high end. but the problem here is that, i get the full bass when i move back from the listening position. i have the monitors placed less than a metre away from my ears. as i monitor from this distance, the bass is barely visible. but if i walk back 3-4 feet, the bass becomes much more visible.
p.s. should i add more mineral wool on the back wall? i know this won't affect low frequencies, but what about adding bass traps in the four corners of my room?
Old 05-31-2006
JeffLancaster's Avatar
JeffLancaster JeffLancaster is offline
Dedicated Member
JeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond reputeJeffLancaster has a reputation beyond repute
Bass traps! Sounds like the bass is building up in the rear corners of the rooms, but the waves are cancelling out in the center where you mix.
Old 05-31-2006
MachWave
Thought so...so you think getting/building bass traps will help me get that sound? my room sounds empty...
Old 05-31-2006
Dedicated Member
All I can say is that from you're description and from everything I've read on this forum and elsewhere, you have a classic case of a room which needs bass traps.
Old 05-31-2006
bpape's Avatar
bpape bpape is offline
Acoustic Designer - GIK
bpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond repute
Agreed. And also probably a shift in the mix position. Sounds like you're also sitting in a broad null.
Bryan
I am serious... and don't call me Shirley
GIK Acoustics
Old 05-31-2006
MachWave
Bryan
What do you mean by broad null?
Old 05-31-2006
MachWave
Could i build my own bass traps using 2-3 layers of 2" pink insulation wool?
Old 05-31-2006
tbone36109 tbone36109 is offline
pwn3d
tbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond repute
i think its possible if you crammed about 12 layers in a 4 inch frame, but at that point it would probably be cheaper just to buy the rigid
Old 06-01-2006
knightfly's Avatar
knightfly knightfly is offline
GrouchyOldFartOnBatteries
knightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond repute
A bit about nulls here -
http://www.johnlsayers.com/phpBB2/viewtopic.php?p=18059
HTH... Steve
Hey, I thought this was gonna be EASY!??!
How to detemine actual decibel rating of monitoring environment? fritzmusic Mixing / Mastering 20 02-28-2006 09:41
NEWBIES using stereo sound cards Article on how to set up your monitoring. manning1 Newbies 10 01-08-2004 05:19
Monitoring equipment: some unconventional wisdom jeffree Other Equipment and Reviews 16 10-27-2003 18:57
Monitoring settings via delta soundcard frist44 Cubase User Forum 0 12-04-2001 16:43
