Old 05-31-2006
blackscot's Avatar
blackscot blackscot is offline
Senior Member
blackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond repute
Bass-Trap Needs (incl floorplan)
Made an earlier post for help with my space and got good feed back at:
http://homerecording.com/bbs/showthread.php?t=200662
Based on that, I'm now fabricating some el-cheapo rigid-fiberglass portable/removable panels to put in the corners as bass traps. Also re-arranged the room to get the workstation better centered (see attached floorplan).
There's a few other furniture items in the room that I didn't bother to draw in, but with the current layout, I've now got the two big corners behind the workstation fairly opened up and can fit a 3-foot wide panel in each.
You can see though that the two far corners are narrower. By the door is limited to 2 feet, so I'll need to make that panel less wide, but it should still be OK. Between the closet and window, however, is only 18 inches.
Because of various (ahem....) domestic issues, I can't really plan on permanently blocking the window and closet with anything. How critical is trapping this corner? Is it worth the hassle of placing and removing the panel there before and after each session, or can I just leave it empty? How about just opening the closet (which is full of heavy garment-storage bags)?
Also notice the in-beween corner created by the jog-out next to the closet. Do I need to get a bass trap in there too?
Any other observations/recommendations greatly appreciated - thanks!!!
Old 05-31-2006
apl's Avatar
apl apl is offline
Stand Up Comity
apl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond repute
Opening the closet, if it's full of clothes will add a lot of bass absorption. Consider simply putting a couple of stacks of rolls of pink insulation in that alcove.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser.
My tunes. Thanks!
NB
DA BEARS!
Old 05-31-2006
blackscot's Avatar
Senior Member
Originally Posted by apl
.....Consider simply putting a couple of stacks of rolls of pink insulation in that alcove.
That was one of the tips showing up in my first post, but that my wife has since indicated as being a non-option. As it is, I'll probably have to cover the rigid stuff with some kind of pastel-colored fabric. As long as it has the desired acoustic effect though.
Old 05-31-2006
apl's Avatar
apl apl is offline
Stand Up Comity
Would she let you put one of these in front of it? That'll give you some nice diffusion.
My tunes. Thanks!
NB
DA BEARS!
Old 05-31-2006
blackscot's Avatar
Senior Member
Hey, that's some nice stuff, and decent prices too!
Actually, an old dresser for storing her off-season clothes partly occupies the jog-out at present, in the corner toward the closet, so only the upper half of the wall section there is exposed.
At this point I'm thinking of just a rigid panel in the corner toward the door and one in each corner by the workstation, plus having the closet open while doing any critical listening. Can always add more panels or whatever later if needed. Not sure how much any mid-wall treatment may help, but got the impression from the earlier post that the corners are the biggest priority.
Old 05-31-2006
apl's Avatar
apl apl is offline
Stand Up Comity
Originally Posted by blackscot
Actually, an old dresser for storing her off-season clothes partly occupies the jog-out at present...
Open the drawers random amounts for more diffusion and absorption.
My tunes. Thanks!
NB
DA BEARS!
Old 06-01-2006
blackscot's Avatar
Senior Member
Cool.
Going to try to get the panels built this weekend. I'll try to post some pics once everything is in-place. It'll be the most lo-tech, bare-bones stuido on the board, but as long as it does what I need.
tracking drums, what sort of room? drummersteve Recording Techniques 20 04-10-2006 16:01
Bedroom Studio :-O thepentium Studio Building & Display 18 12-30-2004 09:16
Preparing drawings for studio. Please check out. Hummarstra Studio Building & Display 24 11-12-2004 16:50
Soundproofing furnace room MrBlackthorne Studio Building & Display 2 01-02-2003 09:55
Wierd shaped room needs planning ola Studio Building & Display 21 11-20-2001 13:44
