Auralex Mineral Fiber?
http://www.sweetwater.com/store/detail/MFiber2/
Is this stuff the same as OC 703? It breaks down to be about $1.87/sq ft. How does that compare?
Myriad Rocker My Web Design/Production Company: Myriad Productions My Band: Black Leaf Clover |
Not really. That material is much denser than 703. I believe that is either 6 or 8lb/cu ft density where 703 is 3lb.
Its the same thing just $10 more expensive... Heres the stuff your lookin for at a good price.
http://www.atsacoustics.com/item--Ow...f-6--1004.html
Bah |
Myriad Rocker My Web Design/Production Company: Myriad Productions My Band: Black Leaf Clover Last edited by Myriad_Rocker; 05-30-2006 at 09:35.. |
"Don't taze me, bro. Don't eeeeyyaaahhhh...." |
If its heavier it should work better on lower frequencies however this improvement might not outweigh the fact that its $10 more per unit than 703.
Bah |
Glenn
GIK Acoustics www.gikacoustics.com |
I have some customers who have used it so I'm familiar with what it is.
Also, contrary to one of the answers, mineral wool is not the same thing at all as 703 or 705. One is made from glass fibers, the other from mineral slag. Besides density, it is a different material, has different gas permiability ratings, and a different matrix makeup. For instance, compare... Roxul Mineral Wool RXL 60 3" 6.0 pcf (96 kg/m3) 0.78 0.89 1.04 0.98 1.01 1.02 OC Fiberglass 705, plain 3" 6.0 pcf (96 kg/m3) 0.54 1.12 1.23 1.07 1.01 1.05 Same thickness, same density, same 'A' mounting tests - very different results - expecially at 125hz. Yes - results vary from lab to lab but not by almost 40% - not if the test is done properly. In addition, the mineral wool is 'springier' than the 705 which is stiffer. So, if you add a scrim face (FRK/FSK) the membrane effect will be different and at a different center frequency. Now, throw in 3" 703 703, plain 3" 3.0 pcf (48 kg/m3) 0.53 1.19 1.21 1.08 1.01 1.04 As you can see, 703 and 705 are much closer to the same thing than 703 and the mineral wool are. All have their place - just a matter of what the room needs Bryan |
| Auralex Mineral Fiber | Shout It Out | Other Equipment and Reviews | 3 | 05-27-2006 07:30 |
| working with auralex mineral fiber | aquaman | Studio Building & Display | 1 | 01-14-2006 18:26 |
| working with auralex mineral fiber | aquaman | Microphones | 2 | 01-14-2006 18:18 |
| 703 or Mineral Wool? | Diffusion | Studio Building & Display | 6 | 10-17-2005 00:03 |
| foam vs. rigid fiber glass | guitarboi222 | Studio Building & Display | 9 | 06-13-2003 08:41 |
