Go Back   Home Recording > User Forums by Brand > n-track User Forum
     Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 05-27-2006
Thatupstateguy Thatupstateguy is offline
Dedicated Member
Thatupstateguy has a reputation beyond reputeThatupstateguy has a reputation beyond reputeThatupstateguy has a reputation beyond reputeThatupstateguy has a reputation beyond reputeThatupstateguy has a reputation beyond reputeThatupstateguy has a reputation beyond reputeThatupstateguy has a reputation beyond reputeThatupstateguy has a reputation beyond reputeThatupstateguy has a reputation beyond reputeThatupstateguy has a reputation beyond reputeThatupstateguy has a reputation beyond repute
OK, so I installed the delta 1010, and
I can't seem to get any of it to work yet,... the Ntrack says it is active,.. but there is no signal coming thru,.... gonna check my source to the delta.... and see if the signal got that far....
but,.... any help would,........
well,....
help.....
Steve
Old 05-27-2006
beezelbubba's Avatar
beezelbubba beezelbubba is offline
Male Lesbian
beezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond repute
Steve,is there an M-Audio icon down in the lil toolbar in the lower right corner of your screen?If so,click on it.It should have your input controls and patchbay router.That's how it is w/my 24/96,anyway.You might be overlooking something simple.
Old 06-09-2006
tmix tmix is offline
1K Silver Member
tmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond repute
What Beeze said!
I have run a pair of 1010s for many years. Once you discover how to use the M-Audio Applet and the Monitor mixer portion you will have all kinds of sound and monitoring possibilities.
If you want to use the applet mixer to control a head phone mix blending what is coming out of the computer with what is going into the computer you will need to assign the monitor mixer to outputs 1 and 2, then go to the monitor mixer screen and unmute and turn up the volume on each track you want to listen to.
Be aware the first 8 faders are what is coming out of the computer and as you scroll the bar at the bottom to the second set of eight faders those are what are going into the delta.
Tom
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
Old 06-13-2006
PhilGood's Avatar
PhilGood PhilGood is offline
Juice Box Hero
PhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond repute
I believe you should also select the input preference as wavemapper. I'll double check.
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life."
M-Audio Tampa to M-Audio Delta 1010 cincy_kid Recording Techniques 3 05-05-2006 18:55
Sonar 2 XL: Delta 1010 will not playback songs recorded with SB Live! MrLip Cakewalk / Sonar Forum 12 08-17-2002 12:55
Delta 1010 with Sonar only has 4 ins and 4 outs OPunWide Cakewalk / Sonar Forum 2 09-21-2001 12:53
Another Delta 1010 setup problem. JimH Digital Recording & Computers 20 08-09-2001 18:49
converter specs for all to read tubedude Digital Recording & Computers 41 05-27-2001 00:16
