Micing up an amp
Hello there, anybody here can suggest the best technique to mic up an amp?? lets say a cabinet....
Does a condenser alone does the job??? ?? |
But, I get the best clean sound out of my amp when I just drop my microphone down in front of it. But, a popular technique is to put a Shure SM57 pointed at the middle of the cone on the speaker but at a 45 degree angle or so, with the condenser facing the body of the cone to pick up lows. Play around with some stuff... see what does what, its fun ![]()
I play lead guitar for a rock band called Indecision based out of Omaha, Nebraska. Check us out here |
Bro, do u hav any short recorded clips/samples of yours that uses the sm-57?? samples of distortion and clean....
it would be very helpful... Does one dynamic mic(sm-57) really helps? or to use 2 mics to thicken the guitar tone?? |
) But I would be more than happy to get some for you when I get home ![]() And yes, the SM57 is the industry standard for vocals, acoustic guitars, and guitar cabs. i record LOTS of stuff with it.
go LDC
If you're getting a good tone from your amp, then one Large Dynamic Condenser Mic is all you really need. Lately I've found it easier to use an LDC than a SM57.
Check out the first three songs here for examples: http://www.soundclick.com/bands/page...m?bandID=68265 The guitars on the first two were recorded with one AT4033, but you can get similar results with an SP C1 or similar. Good luck, Rez |
try everything, double micing dymanic + cond about 3 ft out, triple micing 3 dyn placed in differnt areas, try MS style for roomy sounds, try 2 different amps with differnet combos,
try it, see what ya like |
if you're gonna use more than one mic, minimizing phase issues become paramount...
I'd recommend you stay away for now... |
Keiffer, are those tracks u recorded direct or u mic up the amp dude??? it sounds fuckin' great!!
ANy tricks to share dude???? |
#12
all amps...
get the best tone possible in the mic... adjust your tone whilst monitoring the mic find the speaker's sweet spot. I turn up the treble with no input and find the brightest spot (usually) another method for distorted guitar is two mics. one dead on (sweet spot) straight, the other just beside the first angled about 45 degrees. mix these two to taste for a mono signal. beware of phase issues. you may have to slide one post tracking to fix phasing double (or quadruple) track the same part keith- Last edited by Keiffer; 05-26-2006 at 08:31.. |
| New webpage explaining speaker impedances, etc. | gusfinley | Guitars and Basses | 11 | 12-04-2005 04:27 |
| facts about speaker power ratings | gusfinley | Guitars and Basses | 18 | 01-07-2005 15:49 |
| Micing through a guitar amp... | RyanEmerson | Mixing / Mastering | 2 | 03-28-2004 13:10 |
| mic'ing a guitar amp | The Garage | Recording Techniques | 9 | 04-18-2002 17:30 |
| Micing a Keyboard Amp | vicevursa | Recording Techniques | 4 | 08-18-2001 13:07 |
