Old 05-24-2006
BALKI BALKI is offline
Senior Member
BALKI has a reputation beyond reputeBALKI has a reputation beyond reputeBALKI has a reputation beyond reputeBALKI has a reputation beyond reputeBALKI has a reputation beyond reputeBALKI has a reputation beyond reputeBALKI has a reputation beyond reputeBALKI has a reputation beyond reputeBALKI has a reputation beyond reputeBALKI has a reputation beyond reputeBALKI has a reputation beyond repute
Question Recording vocals seperately?
I just don't get it. I am able to record just fine in Audition , but only stereo. In the past with my onbaord card I could record my vocals seperatley in Audition while still being able to hear the beat while doing it . With this mixer & card I can't seem to do that. The mixer I have is the Yamaha MG 10/2. It doesn't have subgroup outs or buss. I don't know if that might be the issue to this. Is there a mixer out there that can mute the music so it won't read in audition, but i will still be able to hear it through my mixer so i can record just my vocals to the beat? I've tried everything you could imagine with tinkering the settings in audition & mycard settings plus re-routing this mixer. No solution if anyone can help it will be much apprecited thnx.
The gear I'm using
Audio interfaces: M-audio Quattro
EMU 0404
Mixer: Yamaha MG 10/2
When i record in adobe audition the beat gets recorded with the vocals. In multitrack one track is usually the beat and the others are the vocals but when i listen to the vocal part alone it still has the beat and I record with headpones in my mixer.
I have an M-audio Quattro Audio Interface & using a Yamaha MG10/2 Mixer.
Theres only a playback option in the control panel in quattro, but no recording.
Old 05-24-2006
mentalattica's Avatar
mentalattica mentalattica is offline
Just a Home Recorder
mentalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond reputementalattica has a reputation beyond repute
Sounds like a setting. Have you tried selecting record left channel only? Check the CEP board I think there is a sticky on tracks being bleeding onto another track, unless it's headphone bleed. Hope this helps some.
Old 05-24-2006
DrJones's Avatar
DrJones DrJones is offline
Senior Member
DrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond reputeDrJones has a reputation beyond repute
The gear I'm using
EMU 0404
Hey Again!!!
Still not working Eh?
I still think you need a board that has direct outs for each channel. You have a stereo mixer. The drum tracks on Audition are beeing fed to the board and you are recording vox thru 1 channel and the signal cominig out is a mix of the drum tracks and vox. That is because you have no direct out for the vox channel( it's a stereo MIX ). Are you routing the output L&R from your computer into the channel inputs (maybe channel 1&2) and recording vox on channel 3? If that is the case there should be some kind of control room input or stereo input next to the stereo outputs. Plug the outputs there. If that is not the case the you need a new board. One that is made for recording. Hope this works. Describe you signal routing so I know what is going on. I am on a mission now to get your system running. I am suspecting now Signal Routing. I am almost sure it is somthing easy since we went thru all the hard stuff.
Old 05-24-2006
Senior Member
Ok so what your saying is soundcard outs>>> channel 1 &2 of mixer
soundcard ins>>>> 2TR in
Is that how i should route it?
Old 05-24-2006
DrJones's Avatar
Senior Member
NO!!!
Describe your signal route in detail please.
Old 05-24-2006
Senior Member
Ok heres what i did soundcard outs>>>>>>>>> stuck them half way in channel 1 & 2 on my mixer and panned channel 1 hard left & channel 2 hard right on my mixer is this what i do?
Wheres do my ins go?
Thnx for any help man.
Old 05-24-2006
Senior Member
Do you need a picture of my mixer? I took everything out everything completely.
Right now I have my soundcard outs L & R>>>>>>>> Channel 1 & 2 on my mixer
Soundcard ins>>>>> Haven't hooked em in anything yet. Waiting on your suggestion
Old 05-24-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
I would connect the output of the soundcard to the line inputs of channel 9/10.
Connect your mic to the mic input of channel 1.
plug the input of the soundcard half-way into the insert jack of channel one
OR
plug the input of the soundcard into the aux send. Then turn up the aux knob on channel 1 to get your level to the computer.
If you use the insert, the EQ won't get recorded, if you use the aux, the EQ will get recorded.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 05-24-2006
Senior Member
Thnx man that works where i get to hear the beat & just record my vocals. Now if i want to record the music & the beat would i have to switch it to something different?
So when i do this it seems it's only recording out the right channel so in adobe audition do i switch it to mono & select the right channel? Becuase when i chose stereo it was only recording out the right, but when i chose right channel it was recording all the mic signal. I basically have one plug connected in half way in channel one & the other is just out hanging is this right?
Old 05-25-2006
Senior Member
I'm seeming to get good stereo recording with it hooked up like this?
Soundcard Ins>>>>> ST Outs
Soundcard Outs>>>> Ch.1 half way in the insert, Ch.2 half way in the insert
The recordings seems alot better when i record stereo is this a good option?
Old 05-25-2006
Farview's Avatar
Your vocals ar in mono. One mic, one voice= mono
The soundcard outputs should be plugged into a line input. The insert is for tapping off of the channel.
Jay Walsh
  #12
Old 05-25-2006
Senior Member
So this would be better
Soundcard Outs>>>>>>>> Ch.1 line Input & Ch.2 Line input
Soundcard Ins>>>>>>> St. Outs
  #13
Old 05-25-2006
Farview's Avatar
If you hook the stereo outs to the soundcard, you will record the beats with the vocal again. This is where you started.
The reason I would pick channel 9/10 for the soundcard outs is because that channel doesn't have mic preamps. IF you put it there, it is out of the way if, at some time in the future, you need to hook up more than one mic at a time. Channel 9/10 is a stereo channel, so it has one volume control controling the volume instead of two. Personally, I would use the aux for recording so that I could insert a compressor using the inserts.
Jay Walsh
  #14
Old 05-25-2006
Senior Member
So can you show me how you would personally hook it up by writing it like this
Soundcard outs>>>>>>>> ?
Soundcard ins>>>>>>>>> ?
  #15
Old 05-25-2006
Farview's Avatar
Soundcard outs>>>>>>>> line inputs 9/10
Soundcard ins>>>>>>>>> Aux outputs
Jay Walsh
  #16
Old 05-25-2006
Senior Member
On the Aux inserts on my mixer I'm not sure if their outputs? It says Aux send. This is what it says by em.
Aux1(pre)
Aux2
  #17
Old 05-25-2006
Farview's Avatar
Send means output. As in, you are sending something from the board to the...
An insert is something completely different. That might be part of the confusion.
The mixer has three types of connections:
1. Input (mic, line input, etc...)
2. Output (sends, outputs, etc...)
3. Insert (this is a special jack that is both input and output)
Jay Walsh
  #18
Old 05-25-2006
Senior Member
Thx for your kind help Fairview it's really appreciated. Lets say after I'm done recording my vocals seperatley without the beat & wanted to mix it down with the beat how would you do it
Soundcard outs>>>>>>>>>>
Soundcard ins>>>>>>>>>>>
Thnx man if you can tell me your answer to my last question.
  #19
Old 05-25-2006
Farview's Avatar
Soundcard outs>>>>>>>>>>line inputs channel 9/10
Soundcard ins>>>>>>>>>>>main output
Jay Walsh
Recording vocals with EV dynamics? jeak Microphones 46 05-30-2006 07:48
Advice On Recording Vocals! rnb259 DJ & Hip Hop Production 8 04-28-2006 13:31
questions about vocal recording tre2004 Recording Techniques 4 02-22-2006 13:20
Getting Started - Recording Vocals and Guitar, what Equipment? jhaas Recording Techniques 12 01-30-2006 23:40
Recording Vocals SirPsychoSexy Recording Techniques 9 02-06-2003 15:10
