newbie tryin 2 connect triton le cc's, so i can midi with reason 3.04(midisport 2x2 already set). im pretty much set on the tech side adjustin the triton 2 midi channel iz the main problem....so far
thanx |
Asking this in either the midi or the keyboard forum would be a good first step.....
The fact that no one understands you doesn't mean you're an artist... |
are you asking how to use the triton as a midi controller for reason? If so hook up two MIDI cables one going from the midi out of your triton to midi in on your midisport. Then midi in on triton to midi out on midisport. Then go to global mode in your triton le and uncheck local controls.
| MIDI guru needed elect drums soundfonts | wfaraoni | MIDI Mania | 9 | 06-19-2006 10:36 |
| Korg Triton and Pro Tools Need Help with Midi | Next Level | MIDI Mania | 2 | 04-28-2006 07:52 |
| DD-602 midi drum set | raindogred | Drums and Percussion | 1 | 03-22-2005 12:21 |
| Need serious midi help whats the best way to do this? | puppethead | MIDI Mania | 3 | 10-09-2003 15:59 |
| Need serious midi help whats the best way to do this? | puppethead | MIDI Mania | 0 | 10-08-2003 22:00 |
