Go Back   Home Recording > User Forums by Brand > Cool Edit Pro / Adobe Audition Forum
Reply    Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 05-21-2006
Yvon Yvon is offline
Newbie
Yvon will become famous soon enough
recording volume
When I record my guitar or my bass, the recording volume in AA 1.5 is quite low. I would like to record a little bit louder.
My rig consist of:
BOSS ME-50B (bypass)
I use it to go in the computer sound card
M-audio 24/96 sound card
Guitar rig
AA 1.5
I set all the volume as high as I can, but the recording volume in AA is still low.
Is there any way to adjust the recording volume in AA?
Old 05-21-2006
thajeremy's Avatar
thajeremy thajeremy is offline
registered abuser
thajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond repute
you can go to Effects > Amplitude > Amplify/fade and increase the volume here....however, If I were you, Id put some type of pre amp between the boss and soundcard....
do you have a mixer???
Old 05-21-2006
Newbie
I have a small behringer mixer /eurotack UB502. That I use for monitoring purpose only.
I think I will need an upgrade soon.
Old 05-21-2006
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
Let's define "low" here first -
If the "meat" of the signal is riding around -18, -20dBFS or so, that's not "low" - That's "proper and correct."
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 05-21-2006
JoeyPazera's Avatar
JoeyPazera JoeyPazera is offline
Senior Member
JoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond repute
either, go to effects and amplify every track, I use 2.0, and on that i would just go to the mixer and bump it up a couple notches.
Pearl SMX Green Burst
10, 12, 13, 16, 22
Pearl Steel Picillo 13 x 3
Zildjian A and K customs
Alesis MultiMix 16
M-AUDIO BX8a's
Old 05-22-2006
Newbie
This is what it look like:
http://yvongravel.googlepages.com/AA.JPG
Old 05-22-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
It doesn't matter what it looks like. What do the meters say? Your picture doesn't have a scale on it.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 05-26-2006
RideTheCrash's Avatar
RideTheCrash RideTheCrash is offline
Force of Nature
RideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond reputeRideTheCrash has a reputation beyond repute
I'm curious about this myself.
Say I have a snare track. The 'meat' should be around -18? Damn, mine must be up at like 3dB! I assume this is so I have more headroom to play with?
So I want to record a nice 'hot' signal, but only have it show up at like -18 in CEP?
Old 05-27-2006
dobro dobro is offline
Moderator
dobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond repute
Ask Massive what he means by 'meat'. Oh never mind, I'll do it.
Mr Massive: what do you mean by the 'meat' of the track being at -18 dB? And how do you calculate that with Cool/Audition?
Old 05-27-2006
The "meat" - the "bulk" - the RMS for lack of a better term. 0dBVU on the VU meters (if there are any). That should give you around -18dBFS.
Hard to establish with snare and kick hits due to the extreme transient, so in those cases *even lower* would be the norm. But considering the transients, digital peaks around -12 should give put you in the ballpark if you're working with fairly decent preamps. Lower if they're more "budget friendly" units.
-18dBFS *IS* a nice "hot" signal. THAT'S A NORMAL INPUT LEVEL (where do people come up with this "overdrive the preamp" stuff?!? Honestly!!! Where did it start?!?). 0dBFS is anywhere from around 18 to 22dB *OVER* -0dBVU (which is where the preamp is designed to work). That's not how the system was designed...
For the uninitiated, you WILL NOT get "louder" recordings by recording levels that are too hot. For the most part, the added distortion and lack of focus will make it so your recording won't have the potential to handle "commercial" levels when it's finished (as "commercial" CD's weren't tracked with their input levels all 18dB into the headroom of the preamps causing noise and distortion on every single track).
You WILL however get MUCH better sounding mixes (that will handle the "abuse" in the mastering stage FAR better) if you track using "normal" levels.
Go on - Experiment. Record something really hot and then recording the same thing using -18dBFS = 0dBVU. Mix them both using the same scale.
Then ram them both into a limiter.
The one recorded with "normal" levels will easily sound better, clearer, less noisy, less "pinched" in the stereo image, etc., than the one with the "hot" levels.
Old 05-27-2006
ikon's Avatar
ikon ikon is offline
I Want To Learn Audio!
ikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond reputeikon has a reputation beyond repute
^^ok a question regarding that....what if i donwload a beat for instance just to practice this....now all im ading is vocal work and maybe some special effect to the track that is already made (wich is one track) do i leave the track where it is and ram just my vocals into a limiter to match or do i bring down the overall volume of the track (beat), or do i do like a reverse limiter type trick so that i make my vocals match easier? (if you understand what i mean)
  #12
Old 05-27-2006
Force of Nature
Makes sense. I just always read "record as hot as you can, without clipping". I guess that is exactly why when I do mixdown of drums they peak like nuts.
I downloaded some tracks from an article in ProRec, and I noticed the snare tracks for example, all peak at -12.
Thanks.
  #13
Old 05-27-2006
I'm a little lost - You adjust the mix to the proper volume and then record the tracks at the proper volume... The two aren't really related...
  #14
Old 05-27-2006
Originally Posted by RideTheCrash
Makes sense.
You've just entered a larger Universe. Seriously. Your recordings are about to increase in quality by leaps and bounds.
  #15
Old 05-28-2006
Moderator
"Go on - Experiment. Record something really hot and then recording the same thing using -18dBFS = 0dBVU. Mix them both using the same scale.
Then ram them both into a limiter."
John, what happens if you don't hard limit much? Up until now, I've recorded pretty hot, with peaks hitting between -6 and -3 dB on the Cool Edit meter. But after I mixdown all the tracks into a stereo file, I usually hard limit the whole thing anwhere from 2 to 5 dB.
I think my question's this: if you don't hard limit the final result a lot, then recording level isn't such an issue, right?
  #16
Old 05-28-2006
Farview's Avatar
Wrong.
When you record too hot, you are cooking your preamps, the analog circuitry in your converters, etc... This leads to poor signal to noise ratio, distortion of the transients (detail), and most of the time a 'pinched', small sound.
What everyone seems to have trouble wrapping their head around is the idea of average level.
The VU meter on most analog devises is relatively slow. It doesn't show you all the peaks, it shows you the average level. You should set that level at 0dbVU. 0dbVU= -20dbFS in your computer. You are shooting for your average (not peak) level in the computer to be around -20dbFS. So you have to stop looking at the peaks and start looking at what parts of the meter are lit up all the time.
With distorted guitars and other things that aren't very dynamic, it will be pretty obvious. With drums, it's another story. A safe bet is just to make sure that nothing EVER goes above -6dbFS
One or two transient peaks that get up to -2dbfs isn't going to hurt anything, but when the entire track is burning along at -0.1dbfs, you are just screwing yourself.
Jay Walsh
  #17
Old 05-28-2006
travelin travis travelin travis is offline
Banned
travelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond repute
So, would this still apply to a project that only has a few tracks? Say a vocal and a couple of acoustic guitar tracks? I'll admit, I've always recorded as hot as possible without crossing 0 db on my software meters. I guess that's one area in which I just accepted what I was told and never experimented on my own. I'll also admit that I'm guilty of spreading what I was told about recording levels. Thanks for the info Massive Master and Farview. "Leaps and bounds?". I hope so.
  #18
Old 05-28-2006
Force of Nature
So is the whole "recording in the mud" thing, not true?
So the signal on my mixer should read -18 and so should Cool Edit, right? I guess I'm just not used to seeing such small waveforms in Cool Edit.
  #19
Old 05-28-2006
Farview's Avatar
NO. The mixer and cool edit are using two different scales.
The mixer is dbVU
Cool edit is dbFS
0dbVU (on your mixer) = -18dbFS (in cool edit)
Jay Walsh
  #20
Old 05-28-2006
Force of Nature
Ohhh, okay. What does "dBFS" stand for? I know dB = decibel. I assume VU is as in VU meters. Mind you my board has an LED meter.
  #21
Old 05-28-2006
Banned
dbFS: http://en.wikipedia.org/wiki/DBFS
dbVU: http://arts.ucsc.edu/EMS/Music/tech_.../teces_06.html
  #22
Old 05-28-2006
Farview's Avatar
VU= volume units
FS= Full Scale
A VU meter isn't just a thing with a needle. It is a meter with particular balistics. (how fast the meter reacts to signal) The VU scale is always centered around line level. No mater whether line level is +4 or -10, the VU meters zero point will be that level
Peak meters are very fast and are scaled in negative numbers. There is no digital signal above 0dbfs, so there is no need to have positive numbers. 0dbFS is the abosolute limit to the level of signal that can be expressed digitally.
Line level (the level every piece of equipment was designed to run at) = 0dbVU = -20dbFS.
It is a little more complicated than that, but these are the basics
Jay Walsh
  #23
Old 05-30-2006
StephenGiles StephenGiles is offline
Newbie
StephenGiles is on a distinguished road
I think you will get considerably better recordings by not using stupid jargon that nobody can understand.
  #24
Old 05-30-2006
Anybody who doesn't understand that particular jargon has no business recording anything and then asking why it "doesn't sound pro" in the first place.
  #25
Old 05-31-2006
Farview's Avatar
You don't have to know what the jargon means, you just have to realize the relationship between the meters on analog equipment versus digital equipment. It's just like not confusing the type of connectors on a cable with the type of signal it carries. These are just really fundamental things that everyone needs to know.
Jay Walsh
Loud or Soft Volume while recording guitars? zenabi Recording Techniques 14 01-25-2006 12:14
getting high volume on recording playback carollhobi Recording Techniques 5 11-25-2005 16:10
NEWBIES - FINAL ARTICLE - VOCAL, ORCHESTRAL AND CHOIR recording tips. manning1 Newbies 0 01-07-2004 13:54
Volume of recording Neophyte Cakewalk / Sonar Forum 28 07-13-2002 20:11
