Old 05-19-2006
Nalencer Nalencer is offline
Junior Member
Nalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond repute
Live Recording?
I tried to search for this, but the search is acting up on me
So, as to recording acoustic guitar and vocals at the same time. How do you do it? I mean, the bleed issues. Do you just let it happen? Does it not matter if you can hear a bit of guitar in the vocal track and vice versa? Or what? I'm just not sure about it.
Old 05-19-2006
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
Bleed that sounds good is called "ambience." And if you're using cardiods, the amount of bleed shouldn't be objectionable.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 05-19-2006
Gilliland Gilliland is offline
Dedicated Member
Gilliland has a reputation beyond reputeGilliland has a reputation beyond reputeGilliland has a reputation beyond reputeGilliland has a reputation beyond reputeGilliland has a reputation beyond reputeGilliland has a reputation beyond reputeGilliland has a reputation beyond reputeGilliland has a reputation beyond reputeGilliland has a reputation beyond reputeGilliland has a reputation beyond reputeGilliland has a reputation beyond repute
Some people like to use a figure-8 mic on the guitar when recording guitar and voice concurrently. The figure-8 pattern has the strongest null of any microphone type, so by positioning it correctly, you can minimize the bleed of vocal into the guitar mic. Bleed in the other direction usually isn't as troublesome, but you can use two figure-8 mics (carefully positioned) if you want to really try to minimize it on both tracks.
The other approach is to try to position your mics so that the bleed is complimentary to the recording.
Old 05-19-2006
simpleybass simpleybass is offline
Junior Member
simpleybass has much to be proud ofsimpleybass has much to be proud ofsimpleybass has much to be proud ofsimpleybass has much to be proud ofsimpleybass has much to be proud ofsimpleybass has much to be proud ofsimpleybass has much to be proud ofsimpleybass has much to be proud ofsimpleybass has much to be proud ofsimpleybass has much to be proud of
That sure wasn't my experience when I tried simultaneously close-mic'ing vocals and acoustic guitar with two cardiod LDCs.
I had problems that were definitely "objectionable".
It sure wasn't what I'd describe as "ambiance".
I'd call it something more like "phase cancellation hell".
Now I just set up a stereo pair of LDCs a few feet in front of me and self mix the volume by singing and playing at appropriate levels.
The only trick I use is... instead of the stereo pair facing left/right, I orient it up/down (at about 80 degrees) so the guitar is stonger on one track and the vocals are stronger on the other track. Then, I just pan them hard in the mix and it's a natural dynamic sound.
Can I get advice from those who have a home studio? Chrisku13 Studio Building & Display 56 08-21-2006 23:20
Live Monitoring while Recording? Bradley Tanogna Cakewalk / Sonar Forum 16 04-23-2005 17:19
live sound vs recording sound Chris Tondreau Guitars and Basses 6 07-18-2002 20:59
Recording live performances for video telemonster Recording Techniques 4 12-31-2001 16:05
Large Diaphragm Mic ORTF live recording? aloe Microphones 2 06-19-2000 09:30
