Old 05-17-2006
SheHadTheJack SheHadTheJack is offline
Junior Member
SheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond reputeSheHadTheJack has a reputation beyond repute
loudspeaker in box (plus feedback)
tried posting this post earlier without succes, so i might have made a repost.
Anyway. I live in a paper thin appartement in a 4 floor complex, and i wish to record my guitar loud and with feedback. Thats not possible because of my neighbours. I was thinking of making an isolated box with a loudspeaker in it (i have a musicman amplifier and a loudspeaker, so the amplifier would be outside the box). That way i can turn up the volume on the amplifier.
Next step would be to make a loop in the amplifier with a microphone inside the box.
What do you think. Could it be done? Will it work? Have you tried this? Do you know where to find a recipe for an isolated box?
Any comments appreciated (allmost )
Thanks
Carsten
Old 05-17-2006
tarnationsauce2's Avatar
tarnationsauce2 tarnationsauce2 is offline
Welcome to the jungle.
tarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond repute
Well, the feedback is caused by an amplifier oscillation. In order to do that it needs a high gain feedback loop.
Usually that is in the form of the speaker's reaction with the pickups in the guitar.
Simply put, your guitar will have to be in the box too.
OR... (this is unorthodox)
You could wire a pickup inside the box, and parallel it to your guitar's pickup.
But this could have a couple problems.
1. The external pickup will load down your guitar's pickups... your guitar will not have as much output as it should.
2. The feedback will be pretty boring as it won't have the dynamics like a guitar feeding back. Partially because the pickup will be in a static position, causing the feedback to oscillate at a fixed frequency (dependant on how far away the pickup is from the speaker). Also that pickup will really want to feedback even while you're playing since it isn't attached to the guitar and doesn't have the strings to overcome the feedback by overpowering the feedback.
Old 05-17-2006
pandamonk's Avatar
pandamonk pandamonk is offline
Three Thousand and Counting
pandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond repute
I did a plan for an iso box for someone else. Check it out here
Box of assorted used drumheads (Remo, Evans, Pearl, Mapex) nlmd311 Free Ads for Music / Recording Equipment 0 09-07-2004 22:36
old peamp tubes zeppelin Free Ads for Music / Recording Equipment 0 04-27-2004 22:18
What is causing this horrible feedback on my Bose speakers? WinstonCowboy Mixing / Mastering 2 04-16-2004 12:03
Feedback Ferret and DBX Feedback Eliminator and others BaltJack The Rack 2 04-15-2004 19:23
Behringer Feedback Destroyer - It Works DigitalDon The Rack 2 01-12-2004 07:52
