Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-15-2006
lawless lawless is offline
Newbie
lawless is on a distinguished road
_Practical Mixing ?
I recently read "Practical Mixing" by Hugh Robjohns. Anyway, I have a question reguarding this excerpt:
"Whether you're using an analogue or digital mixer, it's
designed to operate most effectively with its faders at or near the 0dB or 'unity gain' position
(sometimes simply marked with a 'U'). This provides the best compromise between a useful
amount of headroom and adequately low mix-buss noise. So, when setting up your mix,
you should open each fader to the unity mark and then adjust that channel's input gain
control so that the signal is at roughly the right level for the final mix. Clearly, you won't
know what that is for sure, and EQ'ing the signal will affect its level too, but you can usually
get it pretty close with a little thought and some experience."
I am mixing inside Cubase sx 3... does this apply to me as well, or just to those with a hardware mixer ?
the mixing contest's are really improving my mixing skills StudioMxpx MP3 Mixing Clinic 2 08-14-2004 15:49
outputs of a mixing desk drummersteve Newbies 11 07-04-2004 15:23
Novice Mixing VSpaceBoy Mixing / Mastering 3 06-11-2002 15:08
Serious Problem w/SYNC: Using Both a 1680 and 1880 with Mixing Control on CuBase rcs Roland, Boss, VS Series Forum 0 08-28-2001 11:18
