Mastering myself
No, this is not some thread about est or Lifespring or any of that bullshit.
I just finished recording and mixing a band. We are all quite pleased with how it has turned out so far, but now the band wants me to master it. I made sure to tell them more than once during the sessions about the importance of having a mastering engineer master the material, and why that was so. I think the underlying issue is really money. As many people do, they expected to spend less time in the studio than they actually did, and therefor spent more money than they anticipated. At "friend rates" no less. The real issue for me is the frickin' loudness wars. The first comment I got from the very first rough mix CD was "Why is it so quiet compared to ....." Arrrgghhh! So I've got all my premaster mixes done. They are 24-bit, 44.1kHz. They average at -12dB but will peak at -6dB. My boss suggested "pretend you have different ears." Uh, funny, Pete, but not helpful. Other suggestions?
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music. __________________ "Do yourself a favour just shut up, read up then put up." --muttley600 Last edited by MadAudio; 05-12-2006 at 20:36.. |
I mastered myself this morning
http://i65.photobucket.com/albums/h2...GFCGjester.jpg Quote:
I will be sending True to spank all three of you directly. But one at a time, you pervs.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music. __________________ "Do yourself a favour just shut up, read up then put up." --muttley600 |
slap a limiter on it, make em happy
http://www.floridadiy.com |
Well I think it depends on the material and what you are willing to sacrifice for relative loudness. The last song I pseudo-mastered had an RMS level of -12db but the peak was right at 0db. Of course slapping a limiter on you music will work to acheive the perceived loudness of the other cds but it always boils down to how much of the dynamic range you are willing to sacrifice. I mean you can use a limiter without completely squashing a mix.
http://www.myspace.com/tazonmyspace
http://www.myspace.com/divercity07 http://www.myspace.com/bigwillz24 Help! I've been censored and I can't get up! ![]() |
There's no rule that says you have to push the volume up so that the peaks are at -.02 or whatever. If you're at -12db RMS average, that might be good enough for your tracks. Don't worry about the peaks. Play the disc next to a similar sounding album and see how it compares. If it's a bit quieter, you're probably in good shape.
G. |
RAMI and SSG - my concern is perhaps the overall mix may need some gentle eq, and it's difficult for me to judge that listening on the same gear. Plus I'm so familiar with the material and how I've mixed it that it's difficult to be objective. I asked a friend of mine if he'd sit in and be a second pair of ears, but he's afraid of being too critical!
#12
A good mastering engineer might be able to "squeeze" mixes beyond the point where they may want to be while grasping at some sort of quality along the way, but many (most) mixes just don't have the volume potential as some mixes utilizing the above specs. |
#13
If your monitors are not to be trusted for overall EQ balances, then you are going to have a hard time of it. The best advice I can give you is to burn off reference copies every once in a while and go listen on other speaker systems, comparing to a big name CD with a sound similar to the band you are working with. You can also most likely squeeze out some headroom by getting a better handle on the low end. shelve or scoop out some of that sub stuff that takes a lot of energy. And adding certain upper & mid frequencies gently can make the mix sound louder. And of course compressing the dynamic range with a compressor and pushing down the quick little transients with a digital limiter. Or if you're really desperate: multiband compression...
http://www.nationalaudiocompany.com |
#14
#15
#16
So can we hear it or what?
#17
#18
Screw the "bad" I want to hear the good.
#19
#20
Allow yourself some time away from the songs if you can. As much as possible. |
#21
If you turn it up LOUD, does it sound good? Not with a compressor, or limiter, just turn the volume up. Does it sound good? If not, try and fix that first.
I won the internets...... |
#22
#23
#24
Have you thought about sending it away for mastering? |
#25
| Mastering, file types, and other jetsam | SouthSIDE Glen | Mixing / Mastering | 22 | 03-19-2006 12:37 |
| DSD Primer | BigRay | Recording Techniques | 0 | 01-07-2006 10:39 |
| 'homestudio mastering' versus professional mastering | Alexander Jamal | Mixing / Mastering | 15 | 05-05-2005 10:05 |
| NEWBIES - THE ART OF MASTERING YOUR SONGS (an introduction) | manning1 | Newbies | 46 | 04-29-2005 14:06 |
| any secrets 4 using vs 1680ex... | drew1 | Roland, Boss, VS Series Forum | 7 | 07-29-2003 22:54 |
