Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 05-12-2006
theront theront is offline
Newbie
theront is on a distinguished road
midi controller that also serves as a midi merge box?
hello i was wondering if anybody knows if there are midi controllers similar to novation remote or novation x station in so that they have 2 midi outs.
now a week ago i was banging my head against the wall coz i couldnt figure out how to connect two keyboards with my triton rack (for live use). Now when using a combi i wanted to use most of the 8 programs and didnt want to split my keyboard into eight parts coz an octave has too small range to play a sound(i want that lead synth to go at least to octaves.) so i want to split the programs on the combi ia a way that there are 3 sounds on midi channel 1 (playing keyboard 1) and the same layout with different sounds on midi channel 2 (using my second keyboard) so i can play 6 sounds at once using bigger bigger range (2-3 octaves rather using 1 with just one keyboard)
now routing keyboards this way,if i got things straight, ask for a midi merge box, to combine channel1 info with channel 2 info and all that going to triton.
but i bought a novation x-station, and accidentaly stumbled to a solution.
i could conect keyboard 1 with x station, then set up the x station so that the signal from the midi-in goes to the out along with the midi info that novation is producing, so it serves as a midi merge box and functions ok.
now because i bought the x station to serve as a stanalone synth and maybe connect to laptop and as it has only 25 keys, i want to investigate if there are controllers that have simmilar possibilities.
so i need to accidentaly stumble to a minimum 49 keys, inexpensive version of the x station. something cheaper than remote 49 300$ (dont need audio interface)
what other controllers can do the job for less money(midi mergers would be a waiste of money if such a thing exists)
tnx
Old 05-12-2006
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
I read your post all the way through four times and I'm still not quite sure what you want.
The way I read it, you are looking for recommendations on a 49-key (or more ) midi controller to feed into the X-station you already have, because you don't want to 'waiste' money on a midi merger and your X-station is providing the part of that function that you need.
Here are links to three that qualify --- one, two and three.
If that was not your question please post again with a more conicise explanation and someone here will try to help.
...now in HD.
Old 05-12-2006
Newbie
yeah it was a bit late when i was writing this message
my first sentence should be
Keyboard A sends midi on channel 2(i got d50) and that goes to keyboard B novation x station which sends midi on channel 1 - and then, from the novation midi out, all of the midi(channel 1+ channel 2) is combined and sent to triton rack. combi is setup so that 3 programs are on channel 1, and 3 programs are on channel 2. so i can play 6 or more programs at once.
now i find 25 keys of the novation are not enough to split 3 programs so i want a bigger keyboard with the same capabilities.
now, lets say that i dont have my x station anymore.
and if i buy, let say, Emu Xboard 49 49-Key MIDI Controller
could i connect d50 to emu xboard and then to triton rack, so that i can play
both keyboards on different channels and that both info goes to triton.
maybe there is a better solution. but the main point is that i want to use 6 programs each covering lets say at least 1,5 octaves range. and i want to have access to all of the 6 programs without pushing any buttons.
Old 05-13-2006
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
I think you are better off just buying a midi merge box.
http://www.misterpotts.com
Old 05-13-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
Just get a cheapo midi controller and plug it in to the midi in on the xstation, that way you will have a full sized keyboard and the xstation to use for keys
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Midi controller no sound recording or playback boyceman Keyboards and Sound Modules 4 10-10-2004 18:42
Midi Help!!! Please geeq DJ & Hip Hop Production 3 03-16-2004 06:06
pro tools midi DOES suck!!! someone PLEASE help!!!!!!!! czar of bizarre Digital Recording & Computers 1 05-18-2003 15:07
Midi controller, Sonar and Reason cstockdale Cakewalk / Sonar Forum 3 02-03-2003 16:34
Advice needed on MIDI Keyboard Controller bullyhill Keyboards and Sound Modules 8 01-28-2003 07:27
