Getting vocals to stand out
Is there anything I can do to make my vocals stand out more in the mix?
Well, besides techniques like parallel compression or certain effects, you're going to get what you might consider obvious answers. But there's a reason they're obvious.
So here's mine: Turn them up. ![]() |
A lot of times it's a matter of making room for them in the mix. If the vocals are trying to occupy a space that is already full, they'll get burried. Space, in this case is comprised of the following elements;
Pan - vocals usually sit in the center of the soundstage. If there's a bunch of stuff already there, it's too crowded for them. Frequency distribution - The vocals will have most of their energy in a certain frequency band. If that frequency band is also very busy, it's too crowded for them. Time - If there's too much happening in the araingement during the vocals, there's no room for them. Volume - If other things are too loud, using up the overall dynamic range, there's no room for the vocals. These elements all interact to create or prevent the vocal from sitting correctly. It's Ok if the Bass is panned center and playing at the same time as the vocal, because it's in a different frequency range. Or some other instrument may be in that freq band, and playing at the same time as the voc, but it's panned out of the way...that's ok. It's when all the elements line up that things compete. |
| where do you sit your vocals? | jugalo180 | DJ & Hip Hop Production | 5 | 03-31-2006 12:31 |
| Removing Vocals from CDs | Knopfler Fan | Newbies | 7 | 11-08-2005 11:51 |
| Vocals Distorting at High Volume? | scarboro78 | Mixing / Mastering | 3 | 01-20-2005 15:52 |
| Recording vocals tricks | arsenaultk9 | Microphones | 26 | 12-30-2004 20:43 |
