Old 05-10-2006
qbert1 qbert1 is offline
Senior Member
qbert1 has a reputation beyond reputeqbert1 has a reputation beyond reputeqbert1 has a reputation beyond reputeqbert1 has a reputation beyond reputeqbert1 has a reputation beyond reputeqbert1 has a reputation beyond reputeqbert1 has a reputation beyond reputeqbert1 has a reputation beyond reputeqbert1 has a reputation beyond reputeqbert1 has a reputation beyond reputeqbert1 has a reputation beyond repute
Need Help Fast!!! Alesis HD24 input problems
Hello,
I rented a Alesis HD24 for a live recording gig tomorrow as a back up. I'm testing it out to get ready for the gig. It won't recognise any analog input. I know the signal is getting to the end of the cable, but the Alesis isn't listening - or at least it's not showing it on the meter. Is there a secret to this machine I should know?
thanks in advance
Old 05-10-2006
robin watson robin watson is offline
Force of Nature
robin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond repute
Input Select button
Lifted from P.39 of the manual:
A single INPUT SELECT button (just below the
display) selects what source will be recorded: the
ANALOG or DIGITAL input. The currently selected
input source is indicated in the lower left corner of
the display.
When INPUT SELECT is set to ANALOG, the HD24
looks to the 1/4” analog inputs on the rear panel
for its inputs. When INPUT SELECT is set to DIGITAL,
the HD24 gets its input from the ADAT Optical
Digital Inputs.
Old 05-10-2006
Senior Member
Thanks, but I already tried that. I should have included it in the original post. Sorry
STILL NEED HELP!!!!
Old 05-10-2006
Seeker of Rock's Avatar
Seeker of Rock Seeker of Rock is offline
InLovingMemory..EZ_Willis
Seeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond repute
Forget the name of the guy I talked to, but when I first got my HD24 I had a minor reset issue, and they talked me through it over the phone, about a 10-minute conversation and the problem was solved. Don't know how late they are up, but I basically did a "system reboot" by pressing a couple of buttons while powering up (after powering down). Really wish I could remember the sequence, but I'll bet that would work
My girl there are just some things that aren't done...like drinking Dom Perignon '53 above the temperature of 38 degrees Fahrenheit
Old 05-10-2006
Senior Member
That may be it, I've poured over the manual to no avail. Anyone know the system reset sequence?
Old 05-10-2006
Senior Member
I found the procedure on rec.org - power on while pressing play and record. No luck!
Help!
Old 05-10-2006
cpl_crud cpl_crud is offline
oh for an hour of sleep..
cpl_crud has a reputation beyond reputecpl_crud has a reputation beyond reputecpl_crud has a reputation beyond reputecpl_crud has a reputation beyond reputecpl_crud has a reputation beyond reputecpl_crud has a reputation beyond reputecpl_crud has a reputation beyond reputecpl_crud has a reputation beyond reputecpl_crud has a reputation beyond reputecpl_crud has a reputation beyond reputecpl_crud has a reputation beyond repute
Are you sure you're monitoring the inputs?
If the blue light below the meter isn't on, then you're metering hte output, not the input.
I severly doubt that you aren't getting the analouge signal.
Try pressing hte "all input" button to switch all meters to monitor the input signal.
If that doesn't solve your problem, then I guess there is a chance that the IO boards aren't correctly seated.
Try playing something back and listening to the output. Are you getting anything out of the Line outs?
If your IO boards aren't seated properly, then there is a chance that you won't get any analouge input (although I'm fairly sure that the unit won't boot with the IO boards not plugged in).
To check, goto the alesis site and find the manual for the EC-1 add-on kit- it describes how to open the unit and seat the boards correctly.
I would give you the URL but I'm busy ATM, will check back when I get home in a couple of hours.
Crud
www.shagtech.com
bad name- average site...
I spend my days getting paid to push around air.
That fact is both amazing and depressing.
Old 05-10-2006
Senior Member
Thanks Crud,
I did try the "all input" feature with no luck. I also checked to see if the signal was passing through - still nothing. In the morning I'll check back to see if you found the "seating" procedure. I'll look too. That may be the cause. The Alesis was shipped to me via UPS. They are bruisers according to insider friends.
You guys are awesome, thanks for the quick responses. Still in need of help!!!
Old 05-11-2006
jkokura jkokura is offline
Force of Nature
jkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond repute
No help here...but I hate UPS
jacob
Upmixed Productions
Old 05-11-2006
chris-from-ky chris-from-ky is offline
workaholic
chris-from-ky has a reputation beyond reputechris-from-ky has a reputation beyond reputechris-from-ky has a reputation beyond reputechris-from-ky has a reputation beyond reputechris-from-ky has a reputation beyond reputechris-from-ky has a reputation beyond reputechris-from-ky has a reputation beyond reputechris-from-ky has a reputation beyond reputechris-from-ky has a reputation beyond reputechris-from-ky has a reputation beyond reputechris-from-ky has a reputation beyond repute
Did it work before you rented it? I mean did you test it before you walked out the door with it? That would let you know if it's your setup or the HD24 itself.
I'd say, unhook everything and completely start over. Follow the manual for the proper settings for inputs and monitoring.
Did you set up a song without enough channels? Try to create a new song with all 24 tracks enabled. Arm the tracks and test to see if anything is getting to the HD24. If not, I'd suggest you take it back and get another one that works in the store before you walk out with it.
Old 05-11-2006
workaholic
P. 22 of the manual says you can set the input mode by holding down input select until it reads "SELECT AUDIO INPUT TRACKS". You should then be able to press the track select button # 13 or higher to make the 24 inputs hear their own inputs. Try that.
Also, There may be a padlock icon on the display. If it is unlocked it should allow changes to the song. If it is locked, you must unlock it. The way you do this is to use the L/R arrow keys to move the cursor to the padlock (or as close to it as possible) and press the U/D arrow keys to make the lock open and close.
I think that's the way. It's been a while since I did that.
The HD24 is a beautiful machine. It's a shame you're having so much trouble. I guess the renter before you made it more of a puzzle than a recorder. Too bad. I hope you get it working.
  #12
Old 05-11-2006
Senior Member
Thanks for all the help everyone. It turned out to be an unplugged ribbon cable on the A/D card inside the unit. Once replugged, it performed flawlessly. The gig went well.
  #13
Old 05-12-2006
workaholic
Congrats. Don't you just love the HD24?
  #14
Old 05-12-2006
bigtoe bigtoe is offline
Force of Nature
bigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond repute
hey - not that homerecording doesn't rule...but check out the hd24 group at yahoo. awesome resource.
i LOVE the hd24!
Mike
www.independentrecording.com
"the first step to having 300-1000 shrink-wrapped CD's under your bed."
  #15
Old 05-12-2006
killmachine killmachine is offline
Senior Member
killmachine is just really nicekillmachine is just really nicekillmachine is just really nicekillmachine is just really nice
yeah those things are a bitch with the stupid ribbons, I bought mine brand new. Never had the input problem like that, When I first powered up it kept saying (HD load failed, check the jumper cable). After swapping it to all positions it still didn't work, so I put it in the right jumper slot and turned it backwards
WHAAAALLLLAAAAA!!!! works great...... You'd thought they'd have put it in the right slot at the factory....
  #16
Old 05-12-2006
workaholic
I bought mine off ebay new in a sealed box. The only complaints I have are the midi jacks are a bit flimzy. And my LRC fastforwards when it's supposed to rewind sometimes but, I usually don't use it since the HD24 is at my fingertips. Still a freaking awesome machine though.
  #17
Old 05-14-2006
Senior Member
It's pretty nice, though I wish I had more time with it. Seemed pretty fool proof.
Alesis hd24 Fireport 1394 countrygerry Alesis Forum 3 03-05-2006 18:54
Metronome Problems LE and Alesis SR16 orientdave Cubase User Forum 0 01-11-2006 08:40
Quick Alesis HD24 Software Question.... newatthis Newbies 6 05-04-2005 16:04
ALESIS HD24 Question... newatthis Alesis Forum 8 05-02-2005 09:08
Looking For Alesis HD24 newatthis Free Ads for Music / Recording Equipment 0 04-18-2005 10:29
