Old 05-10-2006
ryanformato ryanformato is offline
Senior Member
ryanformato has a brilliant futureryanformato has a brilliant futureryanformato has a brilliant futureryanformato has a brilliant futureryanformato has a brilliant futureryanformato has a brilliant futureryanformato has a brilliant futureryanformato has a brilliant futureryanformato has a brilliant futureryanformato has a brilliant futureryanformato has a brilliant future
Ovation Celebrity Deluxe
Ovation CS257 Celebrity Deluxe Cutaway Acoustic-Electric Guitar.
This guitar is absolutely beautiful. It has a slight indentation which you can clearly see in the picture (although it is very small). I have a great reputation in Long Island and NY. You can check out my website at www.ryanformato.com Please contact me at ryan@ryanformato.com if you are interested in buying this guitar from me. For $350 you get the guitar and a HARDSHELL CASE.
You can view the guitar at the following links...
http://notquiterebels.com/guitar1.jpg
http://notquiterebels.com/guitar2.jpg
Here are the specs from Musiciansfriend.com
Strong acoustic voice, plenty of electric punch.
The Ovation CS257 Celebrity Deluxe Cutaway Acoustic-Electric Guitar has a super-shallow bowl to give you ultimate comfort. Offset sound ports permit a unique bracing pattern for extra power and resonance. A slim, comfortable U-shaped neck and bound rosewood fingerboard provide a smooth feel and handsome looks. The neck is reinforced with both a steel truss rod and square aluminum channel, making it resistant to warping or twisting. Comes equipped with OP-30 preamp with 3-band EQ. Includes a preshape circuit that lifts the bass and treble and reduces frequencies below 40Hz. 25-1/4" scale with 1-5/8" nut width.
Ovation CS257 Celebrity Deluxe Cutaway Acoustic-Electric Guitar Features:
Lyrachord composite super-shallow bowl back
High-pressure laminate spruce top with quintad bracing
Mahogany neck
Bound rosewood fretboard
Walnut string-thru pegless bridge with compensated nut
Gold, sealed Ovation high-ratio tuners
Under-bridge piezo pickup
OP-30 preamp with graphic EQ
Built-in tuner
5-piece epaulettes
5-ply body binding
Diamond-and-dot mother-of-pearl fretboard inlays
25-1/4" scale
1-5/8" nut width
Ovation Thunderhead Deluxe hollow body electric, need info undrgrnd studio Guitars and Basses 2 12-19-2005 00:49
Ovation Celebrity. bo.monro Guitars and Basses 11 09-19-2005 18:11
my new-ish ovation celebrity deluxe and a J-station mixmkr MP3 Mixing Clinic 4 12-28-2004 22:34
Ovation Celebrity Acoustic Vice1 Guitars and Basses 8 05-26-2000 01:14
