Old 05-10-2006
MCreel MCreel is offline
Dedicated Member
MCreel has a reputation beyond reputeMCreel has a reputation beyond reputeMCreel has a reputation beyond reputeMCreel has a reputation beyond reputeMCreel has a reputation beyond reputeMCreel has a reputation beyond reputeMCreel has a reputation beyond reputeMCreel has a reputation beyond reputeMCreel has a reputation beyond reputeMCreel has a reputation beyond reputeMCreel has a reputation beyond repute
signal to firepod via patch bay?
So I'm starting my mobile unit. I'm gonna rackmount my firepod (and rackmount my second one when I get it). But in visualizing how to set everything up for doing live recordings I had a question.
Since a live recording in which I use line outs from each board channel will probably not require using the mic preamps is it wise to run the line inputs from the firepod into a patch bay, and then patch the live board outs into the firepod via the patchbay?
I thought about doing this just to reduce clutter and having to run cables around the side of my rackcase. anyone else do this? Good idea or bad idea?
Old 05-11-2006
Dedicated Member
b u m p
Old 05-11-2006
MOFO Pro MOFO Pro is offline
Opinions are like SM-57s
MOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond repute
Great idea... but I'd suggest mounting the bay on the back of the rack if you don't plan on patching alot of equipment into the signal path...
It'll keep the front a bit less cluttered, no snake hanging in the front, but still give you access if you want to direct patch anything.
Old 05-12-2006
riffy's Avatar
riffy riffy is offline
Senior Member
riffy has a reputation beyond reputeriffy has a reputation beyond reputeriffy has a reputation beyond reputeriffy has a reputation beyond reputeriffy has a reputation beyond reputeriffy has a reputation beyond reputeriffy has a reputation beyond reputeriffy has a reputation beyond reputeriffy has a reputation beyond reputeriffy has a reputation beyond reputeriffy has a reputation beyond repute
Probably a good idea. My only advice would be to make sure your patchbay jacks are good and clean as the connections on them can get ratty from lack of use (bad, crackly signal connection: run a jack though each patchbay connection regularly to keep the contact points crisp) There is some stuff out there to spray in each jacks to do this but I can't remember what it was.
new to the patch bay episode52 The Rack 3 01-29-2006 20:56
. . .yet another patchbay question tlp The Rack 19 07-08-2004 13:56
Patch Bay strategies Middleman The Rack 14 04-17-2003 13:18
patch bay recommendations? Voxbeatz The Rack 2 01-14-2003 08:55
knowledge share on my vocoding emerald tablet Recording Techniques 10 08-16-2002 12:40
