Old 05-08-2006
thedude400 thedude400 is offline
Senior Member
thedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond repute
Reverb & Compression, should one come first?
After buying and selling a schload of recording gear to see what I liked best I've finally come down to a couple Lexicon Processors, a little midi keyboard, a firepod, 2 Oktava's MC012's, an SM57, a D112, and a Rode NTK. I'm still waiting on the Firepod so I haven't actually been able to use everything in unison.
Anyways to my question, I was curious as to whether compression generally sounds better before or after reverb is applied. I would rather just use software compression but if I have to I'll pick up a compression unit.
I know it's ultimately going to just come down to "What I like Best" but just curious if one way tends to be more popular than the other. Is there a very noticable difference?
Old 05-08-2006
jaykeMURD's Avatar
jaykeMURD jaykeMURD is offline
Chocolate Rain
jaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond repute
Simply depends on the situation. Some have a preference, but I find I mismatch them all the time.
Old 05-09-2006
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
When you compress a reverbed signal you lose some of what you (probably) worked hard to get --- in other words, you change the sound of that particular reverb setting substantially.
It's a rare situation in which I put the compressor after the reverb, but YMMV.
...now in HD.
Old 05-09-2006
MessianicDreams's Avatar
MessianicDreams MessianicDreams is offline
Throbbing Member
MessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond repute
well as a general rule i always buss reverb, so the wet and dry are never on the same channel.
are you asking whether you should compress the reverb? or whether the signal you send to the reverb should be compressed?
i think its a good idea to keep the reverb as dynamic as possible to be honest...
There are 10 types of people...those who understand binary and those who don't
My humble home studio!
My Choons
My DIY Broadband absorbers thread!
Mbox2, MacMini (Intel), Mackie HR624, Focusrite Liquid Mix, Frontier Design AlphaTrack
Old 05-09-2006
littledog's Avatar
littledog littledog is offline
Three Thousand and Counting
littledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond repute
I never compress reverb. Never occurred to me to do so, and would be hard pressed to imagine why I would want to.
Compression is usually applied as a processor, much like EQ - it affects the whole signal. You COULD compress reverb to change it's decay characteristics, but it seems easier to just change the reverb settings to get the exact sound you want.
Reverb is usually applied as an effect - like chorus or delay - and it is only applied to a percentage of the signal. This is achieved by either bussing the sound with an aux send to a seperate reverb channel, or by using the wet/dry mix on the reverb unit itself.
Mixing secrets by sonusman s_o_n_u_s_m_a_n Mixing / Mastering 261 05-14-2009 19:26
compression, chorus and reverb....help!! Zed10R The Rack 7 05-23-2005 12:29
Tom Lord-Alge giraffe Mixing / Mastering 16 05-15-2005 15:48
Using Reverb mr. torture Recording Techniques 11 08-12-2004 10:02
Free reverb and compression directx pluggins John Sayers Digital Recording & Computers 0 08-14-2000 15:31
