Old 05-08-2006
rockabilly1955's Avatar
rockabilly1955 rockabilly1955 is offline
Dedicated Member
rockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond repute
Need advice with a yamaha mixer
ok this is what i want to do...........not sure that i can with the gear i have right now though. I just got one of the new Yamaha mw10 usb mixers. I actually think its pretty decent, not much noise if any. Anyways, it comes with CubaseLe program. I am trying to record 3 instruments simultaneously and have it outputted as 3 seperate tracks, so i can edit each track individually. But it seems like when i record, all 3 instruments on my mixer get output as a 2 track stereo on the Cubase program. How can i acomplish multiple track, more than 2 instruments, simultaneous recording, and be able to edit each track individually? I dont like recording one instrument at a time because we cant seem to get any rhythm/timing that way. I also have a fostex mr8 (2 track simultaneous recording) if that helps. My comp sound card is pretty basic, it has a mic in, another similar in that green colored, and 5 inputs in the back, for i believe surround sound. I aint looking to spend a fortune either, i just do this as a little hobby. Any advice is appreciated. Thanks!!
Old 05-08-2006
Dr Biscuits's Avatar
Dr Biscuits Dr Biscuits is offline
Dedicated Member
Dr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond repute
Unfortunately, I believe the USB on that mixer only sends out a stereo (master) signal, so if you want to record more than 2 tracks at once, you're going to need to buy an interface that allows this, and mix in your computer (in Cubase).
Something like this http://www.m-audio.com/products/en_us/Delta44-main.html would work for you, if you only need 4 simultanious inputs...
Old 05-08-2006
Dedicated Member
thanks, that delta 44 seems cool. How would it all be set up with my mixer? I also have magix music maker along with cubase LE. I dont know if magix allows multiple track recording??
Old 05-09-2006
tbone36109 tbone36109 is offline
pwn3d
tbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond reputetbone36109 has a reputation beyond repute
yeah usb can only do stereo so its only two tracks(left and right)
Old 05-09-2006
Dedicated Member
Hey rockabilly, if you need to run things through the mixer first (for example to use the mic preamps) then you'll need to route your mixer so that each instrument goes out to a separate output, and then patch that output to the Delta. Then in Cubase select the appropriate Delta channel for each track you record.
For example, you can pan your vocal mic hard right and send it to the right master out, your guitar mic panned hard left to the left master, your back-up vocalist to the aux out. Obviously, you're still limited here by the amount of separate outputs.
However, if you're recording things like direct keyboards, or using a separate preamp, you don't need to go through the mixer at all - just hook it up straight to the Delta and then in Cubase select the correct input for each track you'll be recording.
Hope this helps, good luck!
Old 05-09-2006
Dedicated Member
is there anything out there that is similar to the delta 44, but is not PCI? something i can just connect via USB or Firewire, in the same price range? because i think i am leaning towards just getting the fostex mr8HD, but dont really look forward to spending 4 bills right now. It has 4 simultaneous input recording. I have the original mr8, but its only 2 track simultaneously. I love the fact that i just transfer the wave files to pc and edit through my magix music maker.
Old 05-17-2006
countrylac's Avatar
countrylac countrylac is offline
Senior Member
countrylac is a splendid one to beholdcountrylac is a splendid one to beholdcountrylac is a splendid one to beholdcountrylac is a splendid one to beholdcountrylac is a splendid one to beholdcountrylac is a splendid one to beholdcountrylac is a splendid one to beholdcountrylac is a splendid one to behold
M-Audio makes the firewire 410 and it will allow you to record 4 seperate tracks at the same time. It also has midi input and output and it allows for 8 audio outputs in case you want to mix with an analog mixer. However, a new one goes for about $300 dollars. But you can find one about $70 dollars less on ebay.
Check it out here:
http://cgi.ebay.com/M-Audio-FIREWIRE...QQcmdZViewItem
Old 05-17-2006
random.hero's Avatar
random.hero random.hero is offline
People in the Wall
random.hero has a reputation beyond reputerandom.hero has a reputation beyond reputerandom.hero has a reputation beyond reputerandom.hero has a reputation beyond reputerandom.hero has a reputation beyond reputerandom.hero has a reputation beyond reputerandom.hero has a reputation beyond reputerandom.hero has a reputation beyond reputerandom.hero has a reputation beyond reputerandom.hero has a reputation beyond reputerandom.hero has a reputation beyond repute
hi im retarded
never used a mixer in my life... only recorders that do not require a computer...
so i buy an analog mixer w/ a suitible amount of inputs, if its a stereo mixer, what else do i need to hook up to the soundcard in my computer?
lets say the soundcard is just stock and im not looking to get great quality, but i still want separate tracks... what do i need to buy?
my guess is i'll be using Audacity as a software
::Tripping The Light Fantastic::
GFCG Member No:000 026
Old 05-17-2006
People in the Wall
sorry for bargin in on this thread, but u guys know ur stuff.
Old 05-18-2006
countrylac's Avatar
Senior Member
random.hero, how many tracks are you trying to record at the same time?
Because if it's just 2 then you could use the line input on your sound card and pan one track hard right(completely) and pan the other hard left. All you would need is a two RCA to 1 stereo 3.5mm cable. The conversion would not be all that great, but it would certainly be usable (I should know this is how I started out).
Old 05-18-2006
Dedicated Member
Yep, and if you want to record more than 2 at the same time, you'll need to upgrade your interface (ie get something better than your onboard Soundblaster). Keep in mind also that if you're running everything through a mixer, and sending out a a stereo signal to your computer, you can't "un mix" that stereo signal... you'll need to go through a mixer with enough discrete outputs, or skip the mixer altogether if you have enough preamps or if you buy an interface with preamps built in (which, unless you have a crazy kick-ass mixer, is what I would reccommend)...
  #12
Old 05-18-2006
People in the Wall
lol sweet...
im excited...
thanks for the good advice...
trip the light fantastic...
Vocals into the 2496 soundcard via Yamaha mg 10/2 mixer Trumpspade Digital Recording & Computers 4 05-25-2005 05:33
FA: Vintage Analog Yamaha M916 Mixer RebSeth Free Ads for Music / Recording Equipment 0 05-16-2005 19:28
Attention Newbies: Copy and Save This For Reference!!! (Pt 2) Buck62 Newbies 12 04-25-2005 09:40
Urgent - Opinions needed! Any info on a Yamaha MR-1642 Mixer? rickv Other Equipment and Reviews 1 04-02-2003 23:27
Yamaha RM804 Mixer Problems battleminnow Other Equipment and Reviews 0 01-02-2002 13:48
