Old 05-07-2006
Nick The Man's Avatar
Nick The Man Nick The Man is offline
SOUND
Nick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond repute
Compressing vocals
will compressing/limiting a vocal take completely remove clipping or distortion?
Old 05-07-2006
Dr Biscuits's Avatar
Dr Biscuits Dr Biscuits is offline
Dedicated Member
Dr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond reputeDr Biscuits has a reputation beyond repute
Not if was recorded with distortion...
Old 05-07-2006
SOUND
sorry i worded that wrong what i meant is if i had a chain like this:
Mic>compressor>interface>computer
and was recording the mic being ran through the compressor would it prevent the take from being recorded with clipping or distortion?
Old 05-07-2006
Dedicated Member
Depending on how it's set up it certainly could keep the levels below clip, but it's usually better to adjust the gain instead... for me, I rarely like to record with much compression at all unless its absolutely necessary, because then you're stuck with it... I think the best solution (as usual) is to get the most even performance and mic technique as possible and compress during the mix if you still need it... if you're vocal track i being recorded so hot that it clips, or if the dynamics vary so wildly that a compressor is needed just to keep from distorting, the compressor will have to work fairly hard and may have an adverse affect on the sound... unless of course that's the character you're going for (in which case it can still be done in post)...
My 2c anyway
How to truly record/mix vocals into music properly? Xpred Mixing / Mastering 16 01-01-2006 22:13
vocals, vocals, and more vocals! sacredhill Recording Techniques 6 03-16-2004 22:22
Question On Compressing Vocals RD423 Cool Edit Pro / Adobe Audition Forum 6 08-17-2002 09:53
JoeMeek PC3Q PreAmp for mikes, Compressing Vocals Bodhisan Microphones 5 11-20-2001 06:52
compressing back vocals crosstudio Mixing / Mastering 4 09-28-2001 05:46
