Audio transformer suggestions?
If I were planning to replace the transformer in my Nady RSM-2 with one with less HF roll-off, what transformer would folks suggest? I particularly liked the Shinybox Lundahl samples, so I'm looking for something with that sort of sound, but which Lundahl transformer? LL2911, maybe?
Ideas?
the guy at www.oade.com (Doug)
is a transformer expert. Call him up and pick his brain..he will point you in the right direction.
http://www.capitolflags.com/images/c...ebel-small.gif |
I can't say for certain, but I believe that's the same transformer Shiny-box is using in their mics. I put one in a Oktava ML52-2, it was a noticeable improvement.
See entry #13 http://www.3daudioinc.com/3db/showthread.php?p=4407
It does seem to be an LL2911. Pick them up for $60 here http://www.kandkaudio.com/transformers.html. You can also get them here; http://hometown.aol.com/kevinc927/my.../business.html I have done this mod...it's a good project. It opened up my cheapie ribbon...especially on the upper end.
She's not the boss of me
The only wiring configuration they show (which is oddly described as a "connection alternative") has all of the primary pairs wired in parallel between the two signal lines from the ribbon, which if memory serves, should result in higher power (W) on the output (1+1+1+1:37 configuration). The wiring scheme that I'd sort of pictured in my head was wiring each of the primaries in series for higher voltage output (1:148 configuration). 12 dB of extra gain or higher wattage? Any thoughts?
Nobody????
It's somewhat analogous to using stronger magnets, I think.Where is Marik when we need him ![]() |
Paralleling the primary windings will give the bigger ratio. Putting the windings in series will make for a smaller ratio. Can you post the data sheet? |
![]() Quote:
seems like you're trying to put a precision racing engine into a a Yugo.
| Project files dialog missing many audio files | Ptron | Cakewalk / Sonar Forum | 2 | 12-09-2005 16:09 |
| The Mic Test Thread! | Rhythmschism | Microphones | 41 | 04-30-2004 12:23 |
| ARRGH: Audio folder for recording externally mixed audio in 5.1 | Lopp | Cubase User Forum | 0 | 10-04-2002 15:54 |
| Audio to PC MIDI Sync | mark4man | Fostex Forum | 0 | 07-21-2002 08:45 |
| PC DAW Digest | TAE | Digital Recording & Computers | 0 | 11-25-2000 09:03 |
