Old 05-04-2006
treymonfauntre's Avatar
treymonfauntre treymonfauntre is offline
Magic Bag Of Sounds
treymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond repute
can somebody explain aes/ebu to me?
what are its advantages and disadvantages? i see it on some higher end gear, and it seems like its not very popular anymore? how does it compare to something like adat lightpipe?
i'm also very confused about d sub connections. any light you can shed on this would be very helpful.
i tried searching a few message boards but couldn't turn up much
http://www.floridadiy.com
Old 05-05-2006
BigRay's Avatar
BigRay BigRay is offline
I hate jambands.
Location: Southeastern NC. No more Krauts and Bad music.
BigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond repute
The type of digital transmission has no effect on the quality of the sound as long as no bits are dropped.. S/PDIF, AES/EBU, ADAT LightPipe are all equivalent.All protocols for transmitting digital audio.. The bits carried differs for each of the formats. S/PDIF is basically a domestic version of AES/EBU. LightPipe has the capability of carrying 4 stereo pairs concurrently (8 mono tracks) at up to 48KHz. Its capacity can also be utilised to carry 2 stereo pairs at 96KHz or 1 stereo pair at 192 KHz.
Barring short ADAT LightPipe runs, AES/EBU is normally prefered for professional use because of greater digital signal integrity over the sort of cable lengths encountered in studio and field situations. The Peak to Peak voltage of AES is higher than SPDIF.
Old 05-05-2006
TimOBrien TimOBrien is offline
2.5K Gold Member
TimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond repute
http://en.wikipedia.org/wiki/AES/EBU
Old 05-05-2006
lpdeluxe's Avatar
lpdeluxe lpdeluxe is offline
The Precision Bass Guy
lpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond repute
and also
http://www.rane.com/par-a.html#AES3
"Digo: 'paciencia, y barajar.'" -- Don Quijote de la Mancha, Part II, Chapter 23
Old 05-05-2006
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
Short answer:
ADAT Lightpipe: 8 channel optical
S/PDIF: 2 channel optical (IEC 60958 Type III) or coaxial (IEC 60958 Type II)
AES/EBU (IEC 60958 Type I): 2 channel balanced copper
Beyond that, AES/EBU, with only a few subtle variations, is basically S/PDIF over a balanced twisted pair. It has longer range than coaxial S/PDIF. Most newer devices that speak one can speak the other, but you can run into subtle failures when you try to mix and match the two protocols, particularly with older devices, or so I'm told.
In theory, the range for optical S/PDIF should be nearly unlimited with proper repeaters. I think some devices can also speak AES/EBU over fiber, but I'm not certain. If not, you could always buy adapters to do the conversion and convert it back.
Originally Posted by Obi-Wan
If you mod me down, I will only grow stronger.
Old 05-06-2006
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
aes/ebu audio engeneering soc/european broadcast union ...definate advantage in cable run... as its a differential drive system... spdif if i remember right is sony's /pro dig interface format ... ya may want to check me on that one though.... if you want the good stuff it will have aes/ebu the packets of info are basically the same (data stream/markers etc...)
Old 05-06-2006
Rstiltskin Rstiltskin is offline
Senior Member
Rstiltskin is on a distinguished road
I'm thinking its sony/panasonic digital interface...
of course this is like the difference between trivia and minutia.......
Old 05-07-2006
j-boy j-boy is offline
Senior Member
j-boy is on a distinguished road
... I thought S/PDIF was shorthand for 'Sony/Philips digital interface'?
Old 05-07-2006
Magic Bag Of Sounds
thank you very much. quick question though.. 8 lightpipe channels can only be 48khz, but can it be 24 bit? if not then i guess this would be the advantage of firewire interfaces?
Old 05-07-2006
ez_willis's Avatar
ez_willis ez_willis is offline
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
It is.
Originally Posted by 60's guy View Post
You win.
Old 05-07-2006
ez_willis's Avatar
Virtual Ninja
Yes.
You win.
  #12
Old 05-07-2006
Magic Bag Of Sounds
alright, thats good. thanks a ton everybody!
AES/EBU...XLRs, and TRS patchbays Timbecile Digital Recording & Computers 2 10-02-2005 19:56
AES/EBU Interface Phyl Digital Recording & Computers 4 07-23-2005 07:03
Getting AES/EBU to my computer joshw Digital Recording & Computers 8 07-03-2005 07:45
Can someone explain a mic preamp in non technical terms? Hard2Hear The Rack 15 05-13-2005 21:22
AES/EBU Probs Adeus Digital Recording & Computers 0 10-06-2001 03:18
