Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 05-01-2006
Next Level Next Level is offline
Newbie
Next Level is on a distinguished road
Korg Triton Hum noise
I am getting a constant hum/buzz sound from the keyboard. It is kind of faint, but if I have many layers from the keyboard it adds up.
I have a Korg Triton hooked up to an Mbox 2. I am running 2 cables out of the 1/4" main jacks of the korg and into inputs 1 and 2 on the Mbox. I guess I could filter out the noise in post production, but I want to keep the integrity of the sound.
How can I get rid of this hum?
Matt
Old 05-01-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
Make sure the Triton and Mbox/computer are plugged into the same wall outlet
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 05-01-2006
Newbie
I am still getting the hum noise, but maybe it has something to do with the electricity. I get the noise even if the keyboard is not turned on. However, when I unplug the keyboard, then there is no noise at all.
Any ideas?
Matt
Old 05-01-2006
bsr2002's Avatar
bsr2002 bsr2002 is offline
Denny Crane
bsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond repute
Have you tried changing out your cabels?
Unwanted e-mail = SPAM on the internet (not legal)
Infomercials = SPAM on the airwaves (Legal)
Junkmail = SPAM in your mailbox at home (Legal)
Check Out My Tunes
Old 05-01-2006
antispatula's Avatar
antispatula antispatula is offline
Force of Nature
antispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond repute
calbes are usually the problem. If you're using an unbalanced cord that'll do it too. And if it's from the power supply, try plugging it into a different outlet, it could be a grounding problem.
Old 05-01-2006
punkin's Avatar
punkin punkin is offline
Univalve & Avatar Speaks
punkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond repute
I'm with the other's on this for now...a long hard look at your cables. Are you using both the Left and Right or just a single MONO? IF using both, pull one at a time (find out if the noise is coming from both channels).
Try moving/rerouting the cables while listening to the noise...see if it changes when you move them around. Make sure the cables aren't running parallel and/or in close proximity to power cables and wall warts (the Triton has a big ol' nasty one). It's possible the cables are bad but even if they're not, unbalanced cables are prone to picking up electrical noises.
She's not the boss of me
Old 05-02-2006
Newbie
I fixed it by using converting the 3 prong into a 2 prong adapter. I think called a ground lift. Anyway, thanks for the help. Never would have thought the ground would be the problem.
Matt
Old 05-02-2006
bsr2002's Avatar
Denny Crane
Talking
Matt
I would probably use D.I. Boxes instead of those adapter plugs. Might spend aliittle more money, but it's a little more safer
Check Out My Tunes
Old 05-03-2006
Newbie
What makes this unsafe? I have a surge protector, although it isn't super expensive. What would the DI box do?
Matt
Old 05-03-2006
fraserhutch's Avatar
fraserhutch fraserhutch is offline
Flypaper for freaks
fraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond repute
Will a DI provide ground? Cause I think that's what he gained by using the ground lift adapter.
The fact that no one understands you doesn't mean you're an artist...
Old 05-03-2006
bsr2002's Avatar
Denny Crane
D.I. box does have a ground lift.
Also, just a caution, those adapters do get rid of ground loop problems, but you lose the earthing, so an electrical fault could fry your board and leave you with a live metal case! ...... be careful....
Cheers,
Check Out My Tunes
FS: Digidesign complete system with apple, plus other Cards, and a Korg Triton tubejay Free Ads for Music / Recording Equipment 5 05-23-2006 22:13
Korg Triton Studio Sampler Keyboards and Sound Modules 11 04-01-2005 21:25
Korg Trinity vs Triton... Flo' Dolo Keyboards and Sound Modules 0 01-02-2003 16:51
HS2002 vs. Korg Triton LE punkin Cakewalk / Sonar Forum 8 12-30-2002 10:27
Cubase and the Korg Triton BB Cubase User Forum 0 01-19-2002 06:11
