effects loop sounding horrible.......
I have a crate half stack with an effects loop that has one hole and you have to use a y cable for it.
but when i plug up more than one pedal it sounds horrible. like my crybaby turns intoa horribly weak wah/volume pedal. anybody got any help? |
oh alright thanks.
but what a boss ds-1? when i plug it up it just makes a little bit of crunch and feedback. |
generally effects loops are for effects like chorus, delay, flanges, phaser. run your distortions wha's and compressors and eq(sometimes) to the front of your amp where your guitar plugs in. |
Generally, effects loops are for rackmount line level effects; stompbox type effects usually don't do well in the effects loop. |
. Luckily I returned it to gutiar center and i knew that i screwed up but didn't tell them that, so they relaced the USED one I had bought for a BRAND SPANKIN' new one. It was nice to fuck 'the man' for a change. |
??? The effects loop is for rackmount gear. I dunno how you blew up that Maximizer, but it wasn't from sending it line level signal. |
I have a Boss CS-2 Compression Sustainer, A Boss DS-1 Distortion, A Dime Crybaby, and a Digitech RP-80.
which ones should I run through the effects loop and hich should I put out front??? |
#12
#13
but whenever I use the Digitech RP-80 it always creates horrible buzz when I switch to my distortion channels on my amp. It sounds fine if I am on my clean channel though. anyway to fix that? |
#14
#15
Also, this is somewhat of a budget unit, you know... |
#16
Just follow what Metalj has here and you will be okay, No fuzztones in the loop!!!
generally effects loops are for effects like chorus, delay, flanges, phaser. run your distortions wha's and compressors and eq(sometimes) to the front of your amp where your guitar plugs in. ![]() |
| my effects setup | gitrokr | The Rack | 4 | 07-13-2006 06:42 |
| effects loop - really? | deadfoot | Newbies | 5 | 12-07-2005 07:30 |
| How does an effects loop work? and do you really need one? | capnkid | Guitars and Basses | 11 | 10-16-2005 18:18 |
| List of equipment for sale | Dashley | Free Ads for Music / Recording Equipment | 19 | 06-07-2005 18:54 |
| pedals and effects loop | lesterpaul | The Rack | 3 | 10-01-2002 19:04 |
