Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 04-29-2006
FALKEN's Avatar
FALKEN FALKEN is offline
FALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond repute
question on tubes and marshalls
yo...
I just got a Marshall 50 watt tube amp used. on volume of 3.5 it is very distorted... nothing wrong with it..I would just like to get a cleaner sound out of it. would it be worth it to install a different "hardness" of tubes or something? or maybe to switch from EL34's to 6L6's? I have a fender bassman head that gets a sound I like... I was hoping to get basically the same thing but with a 'marshall' flavor...but not necessarily with heavy distortion all the time. any advice is appreciated. by the way it is non-master volume.
Old 04-29-2006
Outlaws's Avatar
Outlaws Outlaws is offline
Been Here, Posted That
Outlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond repute
Originally Posted by FALKEN
yo...
WHat amp is it?
For a non master volume you need to roll off your gutiars volume to clean up the sound. (and don't be afraid to go all the way down to even a hairline before your guitar gets muted)
Old 04-29-2006
FALKEN's Avatar
it is a 1987x. yes that works but I would like the sound to be fairly clean without having to turn down.
Old 04-29-2006
Outlaws's Avatar
Then you bought the wrong amp.
Old 04-29-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
If you could get it rebiased to take KT88 tubes, you wouldn't have to worry about the power section breaking up, at least not before your ears fall off. However, that won't do anything about the preamp section distorting. For that, you would need to get some 12at7 or 12au7 tubes.
Have you tried pluggin into the low input. That might be your best bet. Marshalls don't really get all that clean.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 04-29-2006
ez_willis's Avatar
ez_willis ez_willis is offline
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
I have 6- 6L6's I'll sell you if you're looking.
Old 04-30-2006
rushofblood rushofblood is offline
Junior Member
rushofblood has much to be proud ofrushofblood has much to be proud ofrushofblood has much to be proud ofrushofblood has much to be proud ofrushofblood has much to be proud ofrushofblood has much to be proud ofrushofblood has much to be proud ofrushofblood has much to be proud ofrushofblood has much to be proud of
you'll have to rebias for those too, so be careful
Old 04-30-2006
killmachine killmachine is offline
Senior Member
killmachine is just really nicekillmachine is just really nicekillmachine is just really nicekillmachine is just really nice
hey EZ_willis what type of tubes are they I'm actually looking to get some.. I hate to but in on this one,,,, sorry guys
Old 04-30-2006
FALKEN's Avatar
ok it could be...
I have a 30 watt jtm 45 that was hand built that sounds great but has the same problem...when I bought this one I figured it would be almost the same sound but at 50 watts it should be as clean as the other 50 watt amps I have played...(many fenders, crate, peavey)....only it is not....the jtm 45 has KT66's.......I wanted EL34's but I really can't tell the difference. I think the guy might have put really hot tubes in there but idunno. why would marshall make an amp that only does heavy distortion and not clean? it makes no sense. these marshalsl were designed to be bass amps. I am not yet convinced this is the wrong amp. i just need some diretion on how to tweak it a bit.
Old 04-30-2006
Farview's Avatar
ok it could be...
KT66's are comparable to EL84's, EL34's are a higher gain tube.
Marshalls were never known for their sparkling clean sound, fenders are. They might have been designed to be bass amps, but that was in the 60's when bass was a muddy, low-endy thing without a lot of definition. It was also common for entire bands to plug into the same multi-channel amp. Volume wasn't as big a deal as it is now. The reason you get a 30 watt Marshall is so you can get it to distort without shaking the building. If you want a Marshall that will be clean at higher volumes, you need a 100 watt version. It still won't be as clean as a Fender and nothing is as clean as a Crate.
Jay Walsh
Old 04-30-2006
Outlaws's Avatar
ok it could be...
Thats wrong. The 1987x was not a bass amp. It was one I know, but not the 1987x. Your amp was never designed to play clean. Your JTM45 was a cpoy of the Fender Bassman. Are you plugged into the low input channel also?
I wouldn't rebias for new tubes like 6L6 becuase even though they will give new character to the amp, they WILL NOT turn it into a Fender...nor will they make it much more clean in requards to what you want.
That amp is a rock amp. Since you have a clean amp you say, bet an A/B/Y pedal maybe.
  #12
Old 04-30-2006
ez_willis's Avatar
Virtual Ninja
Groove Tube GT-6L6GC.
send me a private message if you need anymore details.
  #13
Old 04-30-2006
FALKEN's Avatar
from what I understand the plexi was a copy of the bassman and also designed to be a bass amp. I was under the impression that the 1987x was a re-issue of the jmp-50 from 1974 when they switched the plexi amps over to a circuit board. the faceplate, controls, and inputs are almost identical to the jmp-50.....i have also heard of a jtm-50..don't know if that was actually made by marshall at some point or if that is something the cloners came up with and the 1987x is marshall's response to that. maybe I should trade it for the 100 watt HW edition.... I thought 50 watts would be enough...actually to be honest I just tried the low input and it was wayy better but the low end response is still way too strong in relation to the higher strings. the jtm 45 I have is similar but not as pronounced.
  #14
Old 04-30-2006
DogFood's Avatar
DogFood DogFood is offline
Senior Member
DogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond repute
I suspect if you replace the EL34's with 6L6's and change the pre amp tubes to what the person listed previously you will be closer to your goal of another Fender. Heck, get another Fender.
"Baby, baby, baby, baby, ohhhhh baby" -The Carpenters
  #15
Old 04-30-2006
Outlaws's Avatar
Well, the bassman isn't really a fantastic clean bass amp to start with. The reason Marshall copied it was becuase of the characteristics it game off when a guitar was plugged in. So they took what they like and fixed what they didn't. Hence no longer a 'bass amp'.
But it was never designed for clean at all. It was 100% British rock. The amp will sound bad at anything below about 2 on the volume knob simply becuase the amp isn't working much. It needs to open up and that requires volume and rolling off the guitars volume (if you want a clean sound).
Do what ever you want or whatever is being suggested, but even a 100 watt verion won't be much cleaner. The difference in the two volume wise is miniscule. Yes, the 100 watter will have a bit more headroom and bottom end, but it will still be a broken up clean sound, not a pristine clean. Thats just how Mashall is.
I would suggest this....play anything before you buy it.
  #16
Old 04-30-2006
Farview's Avatar
I would take it back and get something more appropriate for what you are trying to do. Getting the 100 watt and/or changing the tubes won't turn it into a good clean amp. Marshalls just don't do clean (not the tube ones anyway)
Jay Walsh
  #17
Old 04-30-2006
FALKEN's Avatar
well..
I have been playing the low gain input and I have to say that this amp is freaking awesome. and gets me 90% of the way there. it is giving me the right amound of breakup now....and its good to know the high gain inputs are there if I need that sound...I bet one could use a switch pedal for a boost... I am really liking it now...thanks for the help there.
the only thing I would want to improve is the frequency response...it seems to have some harsh sounds around 2k or something...that's a guess I am not trained very well with frequencies but its an annoying upper frequency bite. and the bass is a bit ridiculous but I think I can work through that. thanks again...and as always any ideas are helpful... Also I have some spare tubes here if that would make a diff....I got some 12ax7 backups (GT)...and some EL34 (svelt) and 6L6 (GT) backups also... here is what is in it now: A matched and balanced trio of JJ/Tesla pre-amp tubes (1 ECC803s & 2 ECC83s) and a matched pair of National brand, made in Germany EL34’s. also those are brand new so they might need to just be broken in or something...
I'm not really sure of the differences but I have always played 12ax7's...
  #18
Old 04-30-2006
Farview's Avatar
12AX7's are ECC83's. There is an american and a european numbering system. The ECC82 is a 12AT7. El34's are also 6CA7's, 6550 is KT88, 6L6 is 7027A, etc...
Jay Walsh
  #19
Old 04-30-2006
FALKEN's Avatar
is the ECC803 like a GZ34 rectifier tube or something?
how would these brands compare sound-wise..the JJ/Tesla vs GT and the german EL34 vs sveltana?
I think what I need is a little more warm, a little less bite...
  #20
Old 04-30-2006
Outlaws's Avatar
If you are swapping the same type of tube (12ax7 of brand x with another 12ax7 of brand y), I don't think you find that much of a difference until you have had the amp for a while and really know the sound in and out. YMMV
And for what its worth, EL34 has less of that top end than 6L6 IMO.
This might sound stupid, but you can't turn the Treble knob down a hair to get rid of the 'bite'? What about your guitars tone knob? I think I know the 'bite' you are refering to and I was able to calm it with my tone knob.
  #21
Old 04-30-2006
FALKEN's Avatar
turning the treble down helps but I think that the offensive frequency is more narrow than the high shelf eq...
I have found that different tubes can make a night and day difference but I have always just told an amp tech what sound I was going for and let them decide....only I haven't had a tech in a few years so I don't know.....
ok for now I will assume it is the preamp tubes and see what I can do about that... am I correct in assuming the third tube is a rectifier tube and I should probably leave that one as is?
  #22
Old 04-30-2006
Farview's Avatar
The tube next to the power tubes is the inverter tube.
Jay Walsh
  #23
Old 04-30-2006
Outlaws's Avatar
Well if the tubes are almost dead then they will be a night and day difference.
The recifier tube is generally fatter than the other tubes and almost as big or bigger than the powertubes. The thing is though that your amp doesn't have a recifier tube.
Again, back to the 'bite'.....you are aware of the routing you can do with this amp right? You have hi and low inputs with bright and normal inputs for each of those. You can use a jumper cable between them so you can mix the inputs. http://www.guitar.com.au/amplifiers/...87xinputs.html
  #24
Old 04-30-2006
mx_mx's Avatar
mx_mx mx_mx is offline
The biggest morno
mx_mx has a reputation beyond reputemx_mx has a reputation beyond reputemx_mx has a reputation beyond reputemx_mx has a reputation beyond reputemx_mx has a reputation beyond reputemx_mx has a reputation beyond reputemx_mx has a reputation beyond reputemx_mx has a reputation beyond reputemx_mx has a reputation beyond reputemx_mx has a reputation beyond reputemx_mx has a reputation beyond repute
Are you saying my mg100hdfx does good clean?
http://i65.photobucket.com/albums/h2...GFCGjester.jpg
I reckon I'll have me one of the big 'uns
  #25
Old 04-30-2006
Farview's Avatar
I haven't had a chance to play every variation of Marshall that has come out. There have been a couple that did clean up well, but I don't know which models they were. (or if they are still made)
Jay Walsh
Marshall JCM 900 Question hiwatt357 Guitars and Basses 2 11-16-2005 06:57
Marshall question Elmo89m Guitars and Basses 6 10-04-2005 18:08
Marshall DSL401 BurnBarfield Guitars and Basses 2 10-12-2004 11:56
Good Deals on Groove Tubes Mics?! imacgreg Microphones 0 01-27-2002 20:17
Now that I've got tubes, which ones do I use? getuhgrip Guitars and Basses 17 05-28-2001 19:45
