transformer isolater??
This post could get really long but I'll try to stay
specific... Basically, I need to send a FET balanced ouput from a mic pre into a Tascam 22-2 (of decent/ questionable quality) via the rca line inputs... The mic pre has TERRIBLE hum and hiss when not balanced on input, but is perfectly silent when connected to a balanced input, SO, I'm thinking about building a transformer impedance/isolator box to connect the two. Looking at RADIAL DI boxes, I was pretty impressed with the specs (but not the right connections), and was going to try some Jensens at EITHER 600:600 or 10k:150... I'm pretty sure the inputs on the 22-2 are 10k. Questions: Has anyone done anything like this? Is it very hard to set this up (additional resistors, caps, etc) or pretty much insert transfo into singal path? Which transfo ratio would be best (the pres output is 200-ish)?? Any ideas? Thanks for any answers/comments. . |
| Lundahl transformer vs electrolytics on preamp input | Bob's Mods | The Rack | 17 | 08-01-2005 22:41 |
| Where do I get a transformer for a PV C30 | The_Tallman | Guitars and Basses | 0 | 07-28-2004 21:46 |
| Reporting threads to the moderator . . . | chessrock | Microphones | 19 | 03-05-2004 12:14 |
| Low-Z High-Z transformer question | Andrew123 | Microphones | 5 | 01-02-2003 14:17 |
| Transformer vs. transformerless pre-amp | crawdad | Microphones | 7 | 02-27-2002 06:57 |
