Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 04-28-2006
jokop niv jokop niv is offline
Newbie
jokop niv is on a distinguished road
a delay in midi playback in flstudio
hi all
Im a newbie in recording
I have my midi keyboard attached to my computer
and installed flstudio
no everything is ok while recording my midi in flstudio except
there's a quater-of-a-sec-or-so delay from the moment I hit a key in my midi-keyboard and until the note-sounf in flstudio.
it really bothers me.what to do?
is it common to all midi softwares?
thanks
Old 04-28-2006
DonF's Avatar
DonF DonF is offline
Call Me "Grandpa"
DonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond repute
Do a search on the word latency.
Old 04-29-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
If you have ASIO drivers, use those
there are generic ASIO drivers available from:
http://www.asio4all.com/
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 05-10-2006
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
latency
its possible that the drivers are causing it but not likely... are you playing back samples? or just gm sounds on your sound card? or are you possibly trying to generate then rec and then playback? alot of that could be buffer issues.... not enough data to tell from your description... oh and as to the drivers " almost always " your better off useing the drivers written by your sound card company over generic drivers what programs are you running do they have a history of not playing together.... good luck and yes do google latency...
Old 05-11-2006
Modern_Talking Modern_Talking is offline
Junior Member
Modern_Talking is on a distinguished road
Originally Posted by jokop niv
hi all
thanks
I'm no expert on this but i will share my info on how I managed to solve that same problem for me. . . (of course all the advises came from fellow users here too. . )
I was using a sound card that was built into the motherboard. I used or downloaded all kind of drivers but still had the issuse.
Then I turned everything that was running in the background off (virus scanner/monitors etc) and in the midi software (cakewalk) selecetd the latency to max setting. It did help but then it started to do the same thing again after sometime. So I went out and bought me a audiophile 2496 and till today I never had that issuse come up anymore. Plus I can multitask and still use my midi software too all at the same time. . .
Plus I've read some comments here from some users that they use non-integrated sound cards and they don't really have this latency issue. . . (maybe higher end sound blaster sound card or ??? sound cards) . . .
Old 05-11-2006
I use a AC'97 soundcard for normal computer use and use the ASIO4All drivers when I want good latencey while using my little comp speakers when running audio apps and I get very good performance.
MIDI guru needed elect drums soundfonts wfaraoni MIDI Mania 9 06-19-2006 10:36
FL Studio as a MIDI sequencer? HairWuzEre Keyboards and Sound Modules 1 10-21-2004 12:37
XP30 and Cubase via Extigy == midi delay? Paul Van Dyk Roland, Boss, VS Series Forum 0 07-03-2004 15:39
expansion on the midi problem Ebicaneezer Cakewalk / Sonar Forum 7 04-11-2003 13:58
MIDI Playback stops. Please help. earthcub MIDI Mania 5 12-05-2001 22:35
