Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 04-28-2006
hollywoodending hollywoodending is offline
Newbie
hollywoodending has a spectacular aura abouthollywoodending has a spectacular aura abouthollywoodending has a spectacular aura about
Distortion Pedal for Direct Recording
I'm gonna be running a v-amp pro modeling amp into my comp, since it gets really good clean sounds. However, to thicken up the distortion a little, I want to also use a Big Muff pedal between the v-amp and my comp. Is this wise? Can you get a good distortion sound from a pedal when you direct record? Thanks for your input.
Old 04-28-2006
Outlaws's Avatar
Outlaws Outlaws is offline
Been Here, Posted That
Outlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond reputeOutlaws has a reputation beyond repute
Try it, and if you like it, then its good. What more is there?
Don't limit your texture palette over a internet forum concensous.
Old 04-28-2006
Newbie
thanks, I know.
I just asked because I've heard that direct recording with dist. pedals doesnt work out that good... I'm wondering if anyone here has actually done it and got positive results.
Old 04-28-2006
andydeedpoll andydeedpoll is offline
i do love smilies...
andydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond reputeandydeedpoll has a reputation beyond repute
the Digitech Bad Monkey overdrive has two outputs ... one of them has a cab simulator on it, so you can send it straight into a mixer. i don't know if that helps or not.
Andy
"They're posh round 'ere. They get out of the bath for a piss and Everything."
Old 04-28-2006
tourettes5139's Avatar
tourettes5139 tourettes5139 is offline
ugh..........
tourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond repute
I think that the biggest argument against recording direct in with a distortion pedal usually involves a signal chain like this:
guitar----->pedal------>mixer/recorder/audio interface
and that will pretty much always suck, IMO. I think that having the V-AMP in there will help a bunch compared to not using one.
All that being said, go read Outlaws' post again.
Check out my band!!
www.myspace.com/darkvelvetlaughter
GFCG Membership No:000 019
Old 04-28-2006
ocnor's Avatar
ocnor ocnor is offline
Lord Of The Thighs
ocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond repute
If you want to use a distortion pedal run it into the "Pre DSP Insert" or you will end up with a bunch of niose. If you want a better sound run the V-Amp Pro in "L2 mode" and use the XLR outs or the headphone out which have the Ultra-G Cabinet sim and the extra EQ. The Regular cab sims sound way too thin and honky so I never use them. I've done quite a few experiments with my V-Amp Pro and distortion pedals and it always sounds better without them. An EQ pedal will give you better results than a distortion pedal will.
Old 04-28-2006
Newbie
thanks everyone...
Old 04-28-2006
amra's Avatar
amra amra is offline
1K Silver Member
amra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond repute
You can make it work, I have used an SD-1 in front of it before.
Like Ocnor says, noise can be an issue so you got to watch the gain. Never tried the effect insert, but you can use it in front of the V-AMP just like you would with an amp. Pick a nice clean patch, like the 'tube preamp' into the '78 4x12' cab model, then use your distortion into it just like you would the clean channel of an amp.
Can I get advice from those who have a home studio? Chrisku13 Studio Building & Display 56 08-21-2006 23:20
Amp or pedal for distortion??? Lee123 Guitars and Basses 10 04-19-2005 10:49
ProCo RAT - distortion pedal Outlaws Free Ads for Music / Recording Equipment 3 09-22-2004 15:07
Recording guitar direct from FX pedal photoresistor Recording Techniques 10 05-03-2004 17:24
Recording distortion guitar kikling Microphones 8 08-06-2000 18:40
