Go Back   Home Recording > General Discussions > DJ & Hip Hop Production
Reply    Audiofanzine Dj Dj News Dj Medias Dj Tests Dj Articles Dj User Reviews Dj Classifieds Ads
Old 04-27-2006
grapeboi510 grapeboi510 is offline
Junior Member
grapeboi510 has a reputation beyond reputegrapeboi510 has a reputation beyond reputegrapeboi510 has a reputation beyond reputegrapeboi510 has a reputation beyond reputegrapeboi510 has a reputation beyond reputegrapeboi510 has a reputation beyond reputegrapeboi510 has a reputation beyond reputegrapeboi510 has a reputation beyond reputegrapeboi510 has a reputation beyond reputegrapeboi510 has a reputation beyond reputegrapeboi510 has a reputation beyond repute
Reason Question
ok i have a problem... when i make a drum pattern and put it in the sequencer window... then i change the drum pattern a little... is there an easier way to update the previous pattern with the later one? REALLY NEED HELP THANKS IN ADVANCE
CHECK THE HOTTEST
myspace.com/theturfstarz
Old 04-29-2006
X man Da Legend's Avatar
X man Da Legend X man Da Legend is offline
Vinyl Hugger
X man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond repute
u could just tap the pattern thats a lot easier than the step sequencer in general start at the c1 octave on ur controller
Myspace
Sonar Home Studio 7, Reason 4, Recycle 2, Behringer BCF2000, Ensoniq EPS, Roland Alpha Juno 2, KRK Rokit 5 Monitors, Stanton str8-60 Turntable and Stanton DJ Mixer, Roland XP-30, Korg Tr rack, Korg M3R, Stanton S.252, Lexicon Alpha
Old 05-01-2006
92_ 92_ is offline
Senior Member
92_ has a reputation beyond repute92_ has a reputation beyond repute92_ has a reputation beyond repute92_ has a reputation beyond repute92_ has a reputation beyond repute92_ has a reputation beyond repute92_ has a reputation beyond repute92_ has a reputation beyond repute92_ has a reputation beyond repute92_ has a reputation beyond repute92_ has a reputation beyond repute
There's no way to "update" the pattern. If I may...The next time you program your drums you only use the pads on the redrum to make up a draft for your beat.
Then, after you've put it down in the seq you alter it from there.
I never use the pads on the redrum, I mostly tap my stuff in as X man mentioned, the I adjust and tweak my programming manually. It sounds like it's time consuming, but it's not. If anything it's faster, cause I don't have to deal with problems such as you described above hehe
-Nito
Reason Question for the Pro's rnb259 DJ & Hip Hop Production 0 01-12-2006 12:56
Studio Projects Customer Service Richard Monroe Microphones 107 12-22-2005 16:54
Follow up question concerning MIDI and Reason Repeater MIDI Mania 6 11-18-2004 06:16
Question about Reason bradly Digital Recording & Computers 2 11-04-2004 15:16
MIDI to Reason interface question Repeater MIDI Mania 3 09-28-2004 07:46
