Old 04-26-2006
joe mama's Avatar
joe mama joe mama is offline
Newbie
joe mama is on a distinguished road
The difference between Firewire 400 and 800
Ok, so I am thinking about asking for a Macbook Pro for a graduation present in May. I noticed on the 15 inch versions, there is 1 firewire 400 port, but on the new 17 inch version there is 1 firewire 400 port and one firewire 800 port. What is the difference?! I have a Mackie Onyx 1220 mixer with firewire card and I plan on using it with this computer, but I want to make sure it will still work alright. I read that firewire 800 is a speed increase, but does the Mackie Onyx take advantage of that, or is it designed to work with firewire 400 only? I also tried reading the manual, but couldn't find any sort of answer.
<3
Old 04-26-2006
Soundmind??'s Avatar
Soundmind?? Soundmind?? is offline
Dedicated Member
Soundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond repute
If the Mackie has a 400 card, the 800 will simply operate at the 400 speed (backwards compatible). I'd go with the 800 if possible, as it will be the new standard for the next couple of years till the next upgrade comes along.
Old 04-26-2006
joe mama's Avatar
Newbie
yeah, I would love to go with the 800, believe me! The only reason I am thinking of not asking for that is due to the fact that the Macbook Pro with the firewire 800 costs something like $600 more. Basically what I'm asking is, "Is a firewire 800 port worth $600?"
<3
Old 04-26-2006
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
Macintosh's are 'spensitive.
...now in HD.
Old 04-28-2006
pdadda's Avatar
pdadda pdadda is offline
Captain Sea Boots
pdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond repute
In my opinion, no. For whatever that is worth.
Old 04-28-2006
Chris Shaeffer's Avatar
Chris Shaeffer Chris Shaeffer is offline
Peavey ROCKS!!!!!!!!!!!!!
Chris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond repute
In my experience the main difference is that FW800 cables are even more expensive, difficult to find, and you almost never have the right cable for the job when you need it.
-C
Old 04-28-2006
Keep in mind you're getting more than just a FW800 port for that $600...
One of my main beefs with the Macbook Pro 15" is that it doesn't have a fw800 port. I just really like having TWO firewire ports because I generally need them both. Have 2 ports makes it so I don't need to carry around a PC card to hook up all the firewire crap that I've got.
For me it is a reason to hold out for the machine with 2 ports. I wouldn't care if they were both 400 ports I just want 2.
Take care,
Chris
Old 04-29-2006
Dedicated Member
I think the 400s are quite sufficient for audio work, just saying that if you have a 800 port, it will work with 400s. Should the standard become 800 in a couple of years, you will be able to buy PCI or whatever cards to upgrade to 800 at low cost, certainly less than $600.
Old 04-29-2006
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
Not on a laptop though. Those PCI card upgrades are for desktops only, and I don't think the MacBooks support PCMCIA cards.
http://www.misterpotts.com
Old 04-30-2006
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
No, but they'll do ExpressCard. Eventually, there will be a 34mm ExpressCard FireWire card, I would expect....
*sigh*
I feel your pain.
Originally Posted by Obi-Wan
If you mod me down, I will only grow stronger.
Fireface 800 PC/XP problems. PapillonIrl Digital Recording & Computers 10 03-15-2005 20:00
firewire speed based on cpu or device? andyouandi Digital Recording & Computers 1 12-18-2004 02:24
Firewire 800: is it important for music production? Cliff K Newbies 0 02-13-2004 10:59
firewire vs usb for audio interface? pros and cons of each Veej007 Digital Recording & Computers 12 09-18-2003 20:27
