Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 04-21-2006
woody777 woody777 is offline
Senior Member
woody777 has a reputation beyond reputewoody777 has a reputation beyond reputewoody777 has a reputation beyond reputewoody777 has a reputation beyond reputewoody777 has a reputation beyond reputewoody777 has a reputation beyond reputewoody777 has a reputation beyond reputewoody777 has a reputation beyond reputewoody777 has a reputation beyond reputewoody777 has a reputation beyond reputewoody777 has a reputation beyond repute
overhead drums mics in stereo
Should you use the same model for best results? We have two different condenser mics (not sure of the model as they belong to our other guitarist - I can update the post later). What is your experience?
Old 04-21-2006
petermiller's Avatar
petermiller petermiller is offline
It is what it is
petermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond repute
you should use the same mics or preferably a matched pair for an accurate stereo image. If thats all you have try placing one about two to three feet above the the high hat side about where the snare would be in relationship from frnt to back. and one over the ride side following the symetry of the for mention mic position. both mics face straight down.
Peter Miller
Old 04-21-2006
Russtopher Russtopher is offline
Senior Member
Russtopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond repute
the recording I just did had two different condensers, pencil pointed at the hats/hi tom side of the kit, and a medium diaphragm pointed at the floor tom side of the kit. I thought it came out pretty good, but it was also augmented by a snare mic and kick mic, so YMMV
Old 04-21-2006
Senior Member
Cool... thanks guys. I will also be close micing the kick and snare.
So, if I'm using different mics, should I record two seperate mono tracks?
Old 04-21-2006
Synkrotron Synkrotron is offline
Midician
Synkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond repute
[quote]So, if I'm using different mics, should I record two seperate mono tracks?[/url]
As opposed to one stereo?
I'd alway use separate mono tracks in this situation regardless of my mic setup...
Old 04-21-2006
Supercreep's Avatar
Supercreep Supercreep is offline
Immortalizes Your Member
Supercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond repute
Lots of people use different mics on on OH setup to good effect. I don't know if it's preferable, but it will probably be ok. For rock and pop drum OH i'm not even sure if matched pairs are that important.
Old 04-21-2006
Senior Member
[QUOTE=Synkrotron]
Right, as opposed to one stereo track. I read that a lot of guys like to record overheads in stereo. Is there an advantage versus recording two tracks of mono? Kind of a stupid question maybe, but what's the difference?
Old 04-21-2006
Midician
I'm glad someone's said that... I recently tracked our drummer in his garage using an SM58 on one side and an SM58a Beta on the other... boy did I have to mess with the EQ though (although that was probably more down to me not know zip about tracking).
Old 04-21-2006
Midician
There's no real difference other than with two separate mono tracks it gives you the ability to treat each diffently with EQ or compression, so it's just a question of flexibility really. And you just need to set the pan of one hard left and the other hard right.
Old 04-21-2006
Senior Member
So by recording in stereo, does it just automatically pan one track hard right and the other hard left? Surely there has to be something more than that to it? But maybe not...
So, it sounds like I get more flexibility with recording to two mono tracks and I can use two different condenser mics to my advantage. So I guess the real question is when would you want to use a matched pair and record in stereo? I'm sure each method has it's merits.
Old 04-21-2006
Midician
Yeah. All a stereo track is is two mono tracks together in the same track, each panned hard left and right.
One other advantage of separate mono tracks is that you have more control over both the levels and pan position which enables you to adjust for the fact that you may have had your two overhead mics set up differently...
  #12
Old 04-21-2006
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
I usually record them as mono, and pan them about 65%. Stereo will pan them 100% and you can't change it (as stated above).
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
  #13
Old 04-21-2006
Senior Member
I'd HIGHLY recommend checking out this thread here:
http://www.homerecording.com/bbs/showthread.php?t=39030
Some of the early descriptions might be a bit weird to envision, but read the whole thread, descriptions, and pics. You'll be amazed at the great drum sounds you'll get using 3-4 mics with this technique
  #14
Old 04-21-2006
Minion Minion is offline
1K Silver Member
Minion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond repute
In My setup I have every tom and Drum Miced with OK Quality Dynamic Mics (Amikliv 1 Mics, I know you have never heard of them) and I have 2 Condensers for Overheads (One on the Left One on the Right , One of the Condencers is a Peavey EC-10 and the other One is one That I made myself) and I also have another Condenser that I made just on the Outside of my Bass drum so I use 8 Mics in Total...
Since adding the Condensers as Overheads and one on the Bass drum my Drum recording sound has vastly Improved and I am very happy with the sound, especially with my Bass drum useing a Dynamic close to the head and the condenser just outside the Hole...
All of my Mics all together Cost me well under $200 and the Home made condensers only cost me about $10 each and 2 Hours of assembly, I"m sure once I get some Proper Monitors i will be able to actually hear the sound much better.....
Cheers
M-Audio Delta 44 + Delta 1010LT
5 Piece Drum Kit w6 Cymbals
Custom Made Bass Guitar
Custom Made Les Paul Guitar
Mackie Traction Studio 2.1
P-4 PC w 512mb DDR 80gb HD
Sell you used Equipment Here:
http://www.proaux.com/phpprobid/index.php
Combining mics for stereo recordings Nellsalot Microphones 3 10-09-2005 14:49
stereo overhead image with LDCs treymonfauntre Microphones 4 09-23-2005 18:11
Console names and part names walters Analog Only 51 07-31-2005 03:54
Using different mics as stereo overheads SteveMcB Microphones 1 06-24-2002 14:29
Can I get a good stereo signal for drums with this setup? CorpseGRINDER Digital Recording & Computers 3 02-08-2001 00:36
